pv keeper
jaydenkor
having connectivity issues with pvkeeper 2.0
running windows 10, growatt spf3000tl lvm
pvkeeper connects well enough to gather the logs, but does not show any real time info, if i try to log in the program goes unresponsive and crashes.
anyone know what the issue is? windows compatibility?
UART DRIVER for Silicon labs
CP210x usb
yo hackjack :) got a growatt sph, got the cp210x and got the PVKeeper 2.0 on my Win PC. Using a USB A - - USB A cable from usb ( installer ) socket on growatt to usb socket on my PC ? Cant get it to work,, cant login to PVKeeper ? 123456 or 12345678 ?? ive tryed both with no luck :) please share some inputs :)
123456 works for me, but my Growatt has the USB-B socket on the bottom and USB-A on my laptop. I did have to download the driver and go through Device Manager after it was plugged in and showing an error to get the driver to take, but then it all fired up and worked just fine.
thanks mate,, i did download the driver, but i dont know if i can see it i my device manager ? still no contact :-( i ordered a new usb-a cable just in case..
What I had to do was plug in the USB on both ends, then go into Device Manager and look for the errored device. Once I found that I could point it towards the extracted files via "Browse for drivers" and pointing it at the right directory. Once it installed I opened PVKeeper and it talked with no issues. I made the mistake of trying to install the driver first and it didn't see the device (because I wasn't plugged in) so it wouldn't install the drivers.
