PV output fluctuations
logslogs
MR. K
Pakistan
I have a Growatt on-grid 15kw inverter that's not producing smooth graphs with many small dips over the day. I thought this was normal until I saw a friend's graphs and they were rather smooth.
This is on a normal clear day with no shade/clouds etc. It's the same thing daily.
Please see the screenshot. I have noticed similar fluctations on MPPT voltage too that keeps varying.
Is this normal and what could be causing it?
This is an on-grid/grid-tied inverter so no batteries.
Systems aren't identical. My friend is using a different inverter but at the same 7kw size and in the same area.
So I am not sure if my inverter is faulty or is it something else.
Squirrel. Pesky birds.
Just a possibility: time window of each data point. If you have a shorter window for each data point, you may be showing the actual minute by minute variation.
Otherwise, can you see production by MPPT? It may show if a string has a problem panel.
Thanks for the suggestions. Not many birds around and definitely no squirrels 😄
The wifi module is configured to send data every 5 minutes so it's unlikely it's minute by minute.
Does anything look wrong here in attached screenshots? One for MPPT voltage and another for MPPT power.
Some more graphs attached.
Can anyone tell me if this is normal or if anyone else's graphs look like this.
