About a year and a half ago I installed 200 watts of solar panels on my RV roof, connected them to the pre-wire input on the roof, then terminated them to a PV 16amp breaker in a compartment. I Never got around in finishing the project. We rarely boondock and don’t have an inverter and I never purchased a charge controller, until today! I’m about to install a 12V fridge directly to my lead acid battery with a cutoff switch and an inline 20 amp fuse. So I figured I should finish connecting the solar system and take advantage of having them charging my battery. I know 200w is not much, but it’s a start. After spending over $1k on the fridge I’m Trying to keep my budget down, so I purchased a PWM charge controller. My system specs are as follows.
The panels I installed are 4- 50 W sun power flexible panels, 2 pairs in series, (50W x 2=100W), then in parallel, (100W x 2=200W), to the breaker. The specs on the panels are as follows;
Voltage (VMP) 17.6 V
Current (Imp). 2.80 A
Open circuit voltage (VOC). 21.5 V
Short circuit current (Isc). 2.95 A
Max fuse. 15. A
The charge controller I just purchased is an HQST 20 amp 12/24V controller. The sped are;
Rated Working Voltage: 12V/24V
Solar Input Voltage: <55V
Rated Working Current: 20A
Float Charging Voltage (adjustable): 13.8V; ×2/24v
Over Voltage Protection: 17V; ×2/24v
Over-discharge Recovery Voltage: 12.6V; ×2/24v
Charging Recovery Voltage: 13.2V; ×2/24v
Max. Voltage At The Battery End: <35V
No Load Loss: <10mA /12V; <12mA/24V
Temperature Compensation: -3mV/°C /2V
My question is; is it ok to leave the 2 sets of in series panels in parallel to the controller?
I realize this type of setup is best for a MPPT controller but again, I’m trying to keep the budget down. I read wills book on installing RV solar systems about 2 years ago, but I misplaced it! So I only have been internet searching info.
I have a basic understanding of adding up and not adding up the different voltage’s & amperage’s as it relates to series or parallel, I’m just not sure if I’m going to do any harm or if I’m going to waste the amount of power I’m harvesting from the sun to my system by the way I’m installing everything with a PWM controller?
Any and all advice greatly appreciated by this learning new-B!
Max fuse. 15. A
