irmscher001
Hi all, I need your help! Problem is Pylontech US5000 battery during discharge constant tone alarm sounds with all lights flashing. Solar Assistant shows 0 Watts, 61% state of charge, highest/lowest cell 3.3v. This has happened around 5 times, usually with a slightly increased load of about 12 Amps.
System:
DIY mostly self Installed. Batteries were charged at 49.1v SOC when I turned system on so reasonable level after delivery and storage.
22Kw - 2 x Voltronic (MPP Solar) 11Kw PIP Max in parallel.
6 x Pylontech US5000 batteries total 28.8 KWH
Independent battery cables 25mm2, via 100A NH fuses to bus bar.
Bus bars connected to inverters via 95mm2 cables through 250A NH fuses.
All input/output AC & DC power circuits equal length, inverters and batteries generally sharing load equally.
PV system being fitted soon, hence currently charging at night cheap, discharging in daytime to no lower than 55-70% generally.
I tried attaching a short video showing alarm as well as a few photos of system so far. I think video failed so the photo showing all lights on battery 4 (problem battery) are actually flashing in the photo, and sounding constant tone alarm. Ignore the solar assistant Raspberry Pie cables, not tidied yet, work in progress.
This has happened a number of times, about 5-6 times. Having read on these chat forums and manual, I read this is supposed to mean over voltage, or on forums possibly poor charge balancing between cells insufficient voltage cause.
Batteries have been charged initially each night as per Pylontech automatic settings to inverters ie 53.2v both absorption and float. I tried reducing for a few nights to reduced voltages, then settled on 52.5/51.8. I realise lower voltages were likely a bad idea for balancing. I have therefore had voltages back at Pylontech auto settings 53.2v. I'm now back at 52.5/51.8v. I have tried to give this time to ensure balancing would sort this out, yet again today it has happened yet again. I wanted to reduce SOC yo increase battery life, and thought that caused this. Now I am not sure, is this likely a faulty battery?
Usually this alarm happens when I have a load of 3000-6000 Watts, but equally spread (as proven) this is still only around 10-20A discharge when this happens. To reset I shut down batteries, start them ip again and they run fine, particularly after a charge again. It is always battery 4 the problem on top right side.
Anyone have any ideas on here what I should do? The battery is showing 7 cycles only, it has been charged slowly by grid power from inverter chargers.
Thanks for taking a look at this for me, I have built this following 12 months research and watching and reading everything I could. Generally I have tried to over engineer things and keep things safe as possible overrating cables etc. I'm not an expert, but have tried my best. Without this warning system runs great, is a complete beast, runs anything and everything I throw at it in the house. I have checked everything out with heat camera, everything running nice and cool.
Will's video's made me brave enough to try this project having seen similar, thanks Will! Now just to solve this battery issue.
System:
