Hi,
i'm upgrading a solar system, now it's without batteries and i'm installing a li-ion battery bank.
The battery bank will be 13S (or maybe 14s, i accept suggestions) 4p, i'm using 10Ah cells (in the future i will add more cells)
For the bms i found on aliexpress a Qucc Smart BMS Relay Contactor that works with 7s to 20s packs. It is rated for 200A continus (links for the items in the bottom)
I use a 48V charge controller/ATS/inverter combo with this ratings:
-Solar charge current 80A max (configurable for less if needed)
-Inverter Max current 4100A (5kw continus power output)
-USer-defined battery parameters
it can be connetect in parallel with other units to have more power output or with 3 unit to have 400v 3phase (not needed for now but maybe yes in the future)
My budget is around 150€
Is this bms good for my application? Does anyone have experience with it?
Do you suggest this one or a 150A-200A daly bms with Common port?
BMS https://www.aliexpress.com/item/4001316225854.html
Inverter/charge controller https://www.masterbattery.es/en/omega-x.html
