Hi,
I have been testing various solar panels and a couple different controllers.
When I connect a 100 watt panel directly to a multimeter and measure the voltage and current I get 20.8 volts and 4.7 amps, which is pretty close to specs.
My question is;
What do the controller voltage and current reading actually represent? Do the controller readings reflect the voltage and current that’s being delivered to the battery dependent on its state of charge and load? With the test battery at a resting voltage of 12.25 volts, the controller was reading 19 volts and 1.1 amp. I know the function of the controller is to regulate the charge voltage and amperage to the battery, it just seems that in the past when I was looking at the charge controller amperage it was always much higher.
The controller is a Renogy 30A PWM but I’ve also used a Victron MPPT with similar results.
This is just bench testing with all components in close proximity connected with10 AGW wiring and no load.
Does this seem like normal operation? Am I just not understanding the measurements that I’m getting from the controller?
Thanks in advance for any comments or educational opportunities you can provide!
My question is;
