Cussewago Rifleman
Hi all,
I am currently building a 400 ish watt system using Will’s book and videos.
My current setup is a 2200 watt pure sine wave inverte, epever 40 amp mppt charge controller, LIFePo4 batteries.
I pick up 4 of these panels locally and was double checking to see if using one of these panels for my little system. Also note, I am mounting my components to plywood and mounting the plywood to a dolly to making it portable. I am intending to make a portable ground mount for the lone panel to use with this setup.
Thanks in advance for feedback.
Here is a pic of the specs on the back of the panel:
![8484BBE5-D256-4DAC-B352-12EB8BEC0BE8.jpeg 8484BBE5-D256-4DAC-B352-12EB8BEC0BE8.jpeg](https://diysolarforum.com/data/attachments/145/145478-d135e4326844c450b321045a37a7a770.jpg)
