Hi, I'm pretty new to the space as I was looking to purchase an ecoflow or bluetti and found out it's way cheaper to DIY. The problem is this seems somewhat complex and time-consuming (not as easy as advertised). I'm seeking to gather a consensus on a build of materials for a portable LiFePO4 system using this battery at the core:
- ECO-WORTHY 12V 280Ah LiFePO4 Lithium Battery, 6000+ Deep Cycles, 3584Wh Energy
- What size solar controller do I need?
- 4,000 watt inverter
- Wiring kit - TBD
- Pelican case
- Touch pad switch panel
- What panels and wiring would I need? (Max charge voltage: 14.6V)
