Thank for this very good answer!What this means is that no matter if your house battery pack is 12, 24 or 48 volt, it will require a battery to battery charger to charge from the normal vehicle alternator.
Thank you!So I can't be bothered anymore trying to figure out what you meant- have fun with it all, I'm off
(as for the rest of your comments- no comment from me lol)
Banish that thought.
That’s 8x or more depending on battery of typical acceptable charging rates.
At 3:18 in the video you see the info of the charging!Can his system just draw the current it needs/is set up to draw?
I mean, the charging station doesn't push the current.
Charge at 200 A or whatever he sets his system up for?
First, thanks for this great and intelligent answer!Hi @JohnD0h
I guess you want what you want & are experienced enough to sort it out.
So have you done a “Load Calculation Spreadsheet” / “Energy Audit” ? If so, if you post that here, I can be of more help.
I see you have 4 battery choices, but without knowing the other system components, you are asking the forum members for opinions or design help only identifying part of your intentions. The forum can be helpful to you, but the more info you provide the better the help might be.
So “What is the best path for you”? ,,, IMO, slow down & perform as much of a complete design as you are capable of, post that, & get that design vetted here.
12vdc / 24vdc / 48vdc ,,, Why are you choosing 48vdc in such a small RV “VW T-4” ?
Right. But the weeds grew, and the 10mm socket got lost in the growth.the charging station doesn't push the current
He can set up any chraging current to suit his needs. A 48kW electrical panel doesn't push 48kW when you plug in a toaster, the toaster draws the 1.8kW it needs, and the un-used potential is safely waiting for other loads.Right. But the weeds grew, and the 10mm socket got lost in the growth.
Hi everyone and thanks again for your help!
You make me redo my homework.
The first year, I’ll have access to the AC from where I’ll do my build so I only need DC for led, diesel heater, water pump some computer fans… if I don’t miss anything and for that I can go with a Li Time 12V or 12.8V 100Ah and a fuse box and keep the cost around CAD 500$.
And in a year I'll build a second system separate from this.
So I have one more year for planning my electrical system!
My van will be isolate and heat all the winter with a diesel heater.
Cooking and fridge will be on propane.
I don't want anything else than LiFePO4 Lithium Battery.
I know that my need will be around 2KWh/day and I want around 5KWh to 6KWh in battery.
So my second system will need to have 4KWh to 5KWh.
I keep the door open to go 12V, 24V, 48V!
***The goal of my post is to learn what do I need in my system to:***
What do I need to charge with an EV public charger (7.2kW)?
What do I need to charge with a car alternator?
What do I need to plug in a camping site?
What do I need to plug in a 120V AC house?
I have see on YouTube some people who have use the EV public station to charge the battery in their VR and that was working.
The best info I have found is from this video and it's look like it's working well with his 24V 300Ah battery:
From what I understand so far is that the terminal has a voltage of 240V, a useful power of 7.2KW with a J1772 connector.
With a 240V to 12V/24V charger, a J1772 to NEMA adapter, it is possible to charge 12V and 24V batteries.
I'm here to learn more details about how and with what I'll able to do it and have more user feedback.
It'a 4 minutes video, please take the time to watch it before answering something about EV charger.
I also have a question for my fellow Canadians who have solar panels installed horizontally on the roof of their vehicle!
I want to know how much cost effective it’s and what performance it give you during summer and winter in Canada?
If I choose to add solar to my build, it’ll probably be a commercial panel between 400W to 550W and 60 or 66 cells from what I know about solar for now.
Thanks!
Thanks for your reply, nothing again nobody, but come on guys, try to keep my post clean as possible, and it probably already have a lot of post where you can talk about the rest that I'm not here to learn!
Look at the first post in page 2 to see what I'm looking for now! Thanks!
Pat
Actually it is quite possible to use a dual battery setup in a modern vehicle with 'active' regs- you just have to be careful about where you wire the second battery charge point to... (some monitor the negative side, some monitor while the positive side, I've done quite a few of both...)
500W and going to 24v???
You'd hate my 12v 8kw continuous, 16kw peak inverter then lol
You need a charger!What do I need to charge with an EV public charger (7.2kW)?
Big thanks RV8R for all the time you have take to give me all that clear and quality info, it's really appreciate!Hi @JohnD0h
So This post will be long.
First, I am going to give you more grace than I generally do on forums, as I understand english is not your first language & that can be difficult & things can be lost in translation. I would be lost if I had to communicate in Francais. Un peu de francais, but not much.
So where to Start ,,, EV Charging ,,, I have not done it, so not much help here, but I do have a few comments about the videos you posted;
Sprinter Guy Video; This can be an issue on YouTube. IMO, I do not think many DIYers would catch this & tge risk is possibly low ,,, but ,,, if you do not know what this DIYer did here, he compromised the oneway “exhaust only” of the driver’s side rear interior air relief vent. Sticking a cord thru that device can create an inlet for tailpipe exhaust fumes & especially if the rooftop fan is exhausting interior air. Possible yes, unsafe maybe, probable.
Careful who you “follow” out there.
This is not impressive charge rates for me for EV charging;
Next Up ,,, Single Handedly Saving the World with his Diesel Guy;
Ok, I lasted to 4:31. Maybe I bailed early, but the 1/4 of the video I watched was just ego back-patting & verbal diarrhea about how great he is being charging up his diesel van with EV chargers sometimes for free. Sorry, but I will not waste my time ( again ) watching such dribble.
If you want me to watch a video now, please post the timeframe in & the specific item you are asking about, otherwise I am too busy.
On to your questions;
7.2 KW EV ,,, I don’t know, but is that something you want in a T-4 ?
Car Charger; in short a “Great Alternator” & a “Good DC2DC” like a Kisae. 30amp 50amp 100amp now ,,, they are dual “alternator & solar” chargers
Campsite;
This ( dual or single );
& one of these if the Campsite has 30 amp only ( Caveat - careful on selecting these as you want an adapter that plugs into the campsite pedestal & then into a 15amp extension cord heavy gauge ). I use a 30amp shore inlet on my van, so I have gone another method & this suggestion has not been vetted by me );
For 120Vac House ,,, See above NOCO.
If you want to see my 30amp Inlet on my van go here;
RV8Rs New Build - TETRIS
www.promasterforum.com
Onto your “Load Calculations” or “Energy Audit”;
I was having difficulty deciphering this, however, now that I have a second look at it, I understand the word in French for days and that the “J” is not for “Joules”. When I first looked at this, I was very confused with the. “J”.
So what is your total KWh use per day ?
FYI, here are a couple of examples I did for DIY van builders to help them understand their needs;
The last one was more complicated & incomplete for information input.
The next comment is for “clarity only” & I think you know this;
A Watt “W” is “Power”
A watt hour “Wh” is “Energy”
If you calculate your energy needs in “Wh” rather than amp hours “Ah”, then we can disregard the battery or system voltage calculations. It is the purist way to calculate.
On a “Final Note”;
This Victron “Wire Unlimited” pdf / manual teaches the very basic to help DIYers understand & learn. If you know everything in it then bypass it ,,, but if not ,,, help yourself out by reading it ,,, I highly recommend it & it is free self paced learning;
Ok; I’m down from my soapbox now,,, Not Soon Enough they say !!
I think that I prefer that than solar panel in Canadian climate, and we have thousands of EV public station here in Quebec!
I estimate that my need will be around 2KWh/day and I want around 5KWh to 6KWh in battery.
So my second system will need to have 4KWh to 5KWh since I'll have a first year, separate system with 1280Wh for my DC only during my build.
Thanks for the reading recommendation, I know I still need to learn a lot about electricity
There is quite a bit of sun here in Quebec for a huge part of the year (simply forget November, december, january).I think that I prefer that than solar panel in Canadian climate, and we have thousands of EV public station here in Quebec!
I'll live in my van 12 month/year so I can't simply forget November, December, January!There is quite a bit of sun here in Quebec for a huge part of the year (simply forget November, december, january).
Panel are cheap now and give you free electricity.
To me, it seem annoying to highly rely on public station to charge.
And watch out when you will realise that a 6-7 kW charger cost 4 times what a simple solar set up can cost.
Bop, with all my respect, can you start your own post please!That's just it- by staying at 12v (or 24v for larger motorhomes based on a truck or bus chassis), you can use the alternator to charge the battery bank while driving- arriving there with your battery bank fully charged and ready for action...
(plus it means in an emergency, you can start the engine up and 'fast idle' it as an emergency generator- yes its relatively inefficient, but it works lol)
A 100A 12v nominal car alternator is capable of over 1200w/1.2kw per hour of use- an equivalent solar array is five of my 250w panels- which would pretty much fill the entire roof of a long wheel base Sprinter van...
That's a 4wd Hilux parked near the shed in comparison
That 5 panels would just fit on the roof of this Mercedes Sprinter LWB van (commonly used for motorhomes)
Makes little sense to drive to an EV charger (which takes how long???) to charge up (at a cost- 'free EV' chargers are rare and becoming rarer)when the alternator could have literally done the same job while driving to and from the charger in the first place lol
Could be great, but that not my plan!Drive south for the winter?
come back in the early spring before it gets too darn hot in the south?
Geese do it.
You have to speak of power (watts) or at least in amps, like 24V x 100A = 2.4 kW.And it's not a 6-7 KW charger, it's a 240V to 12V-24V charger
