Budget build...
A 120$ J1772 adapter + a 150$ charger (Mean well RSP-500). It seem like a low budget solution to me.
But the RSP-500 is an open frame fan cooled power supply who can only output around 700W, so I don't consider it as a ''good'' charger.
It will work, on 120V and 240V, but a 2.5 kWh battery will need up to 4 hours to charge, so what about the 5-6 kWh Johnd0h expect to have
With low resolution design & budget, “we” are assuming lots here. I have worked 4 decades in the construction industry with budgets & design, & the way to start this process is by identifying the needs & them preparing a rough budget to see if it is economically feasible.
I see so many DIYers, just start buying things even without a design let alone a budget. Without needs being identified, design being researched & performed, & a rough budget being calculated
@JohnD0h is proceeding in the dark.
He is starting out with a 2.4 kWh battery ,,, $270 ( adapter & charger ), might be nothing for you & I along with the additional cost items that will be required to make it work, but might be an expense better spent elsewhere ,,, depending upon needs, design, & budget.
Intended use ,,, Fantasy & Reality are 2 separate things. What the heck does that mean
? OP might have the idea of fantasy of rollin up on an EV Charge Station with his ICE T-4 & charging up in 15mins. Where in reality ,,, due to “The Power @ Hand”; be turned away, or limited plug in time, or charged by the minute, or whatever else we can’t fathom our Governments or Power Providers or other entities will dictate to us.
Fantasy vs Reality
,,, RV8R ,,, You paranoid freak !! ,,, Well here ya go ,,, Fantasy relies upon reality & the control of others not infiltrating the Fantasy;
electricvehicles.bchydro.com
Depending upon the area you might have your fantasy play out & what changes the authorities are making, might throw a wrench into the mix.
ICE vehicles rollin up @ EV charge stations ,,, How long do you think “they” will allow that.
That is all I am trying to convey ,,, that & a reconsideration on 12vdc or 24vdc.
