littleharbor2
Understandable. I've been doing off-grid solar for 25 years so I guess I just take it for granted that everybody, (not everybody), knows Morningstar.I never had either. We weren't all in the off grid scene back when.
Is there any transformer hum like a Victron? Looks like the SureSines have Bluetooth support out of the box in addition to various hardware interfaces.The quietest inverter you can get is a Morningstar SureSine. They have one that is continuous output of 2500W. It is quiet because it is completely designed for passive cooling with large heat sink. There are no fans. I have the 150W version. You'd need separate charge controller.
I only have the 150W and it's barely audible. They also still do not have the iOS app available for bluetooth access but the Android one is available.Is there any transformer hum like a Victron? Looks like the SureSines have Bluetooth support out of the box in addition to various hardware interfaces.
I only have Android but this doesn't work for you?I only have the 150W and it's barely audible. They also still do not have the iOS app available for bluetooth access but the Android one is available.
I just hooked up my 2500w version today for the first time just to test it out. When it was running at 750 watts, there was a pretty faint hum. Didn't have any more quiet loads to throw at it. It ran handheld power tools fine, but would not run my 15 amp miter saw. The app worked fine on my apple phone.Is there any transformer hum like a Victron? Looks like the SureSines have Bluetooth support out of the box in addition to various hardware interfaces.
Thanks for the info. What battery system are you running? Maybe that dipped low when you tried the miter saw?I just hooked up my 2500w version today for the first time just to test it out. When it was running at 750 watts, there was a pretty faint hum. Didn't have any more quiet loads to throw at it. It ran handheld power tools fine, but would not run my 15 amp miter saw. The app worked fine on my apple phone.
Ahh.. they must have just released it. It wasn't there last week.The app worked fine on my apple phone.
You have the new Morningstar 2500 watt Suresine? It would not start your 15 amp miter saw? That is interesting as they list a 5kw surge rating.I just hooked up my 2500w version today for the first time just to test it out. When it was running at 750 watts, there was a pretty faint hum. Didn't have any more quiet loads to throw at it. It ran handheld power tools fine, but would not run my 15 amp miter saw. The app worked fine on my apple phone.
That sounds like a weak battery/bad cable situation.You have the new Morningstar 2500 watt Suresine? It would not start your 15 amp miter saw? That is interesting as they list a 5kw surge rating.
Could you please confirm the no load idle consumption?
The Suresine 2500 watt has a :That sounds like a weak battery/bad cable situation.
Edit; After reading back into the whole post, You are asking a lot of your 2000 watt inverter after running a 750 watt load and THEN hitting it with the surge that a chop saw would draw you are probably asking a bit too much of your inverter. The 5000 surge rating is probably shorter, timewise. than your Chop saw needs.
Exactly?I don't care about remote monitoring. I would never network my offgrid setups. The entire intent for me is airgapped systems. I've got two legs. I can walk over and look if I want to know my system's status.
