PreppenWolf
Solar Wizard
- Oct 10, 2022
- 1,010
Would like advice on doing a stand alone 3kW cabin build.
I have a full house build already. Here link to it.
diysolarforum.com
I'm in NH so the batteries will be lead acid due to cold weather and no heat in cabin. I don't need help choosing batteries.
Planning on 48V.
Want 3kW 120V AC, single phase.
Panels I have covered and on hand already I can assign up to 5kW.
My big questions are:
Quiet inverter options? It's a small cabin 12ftx16ft.
Lowest idle consumption?
Ability to load shed excess to a heater for winter?
I'm currently thinking Growatt SPF 3000TL. Any reasons with my questions above I shouldn't go this route?
EG18KPV (formerly 6500s) 120/240 Setup, 48V 105kWh Battery & Overkill 100A BMS Install
Edit 3/4/25 - EG4 18K has replaced the 6500EXs. No changes to battery or panel capacity. PV strings altered to 10s2p, 10s1p, and 10s1p for the (3) MPPTs on the 18k via a new 6 to 3 combiner box. EDITED: I've made this my build thread, so while there is an OP question below if you keep reading...
Planning on 48V.
