Tldr: Nitrogen at 25bar/360psi shows no leak but vacuum seems to leak a but.
First let me say thanks for the great video by Will about a mini split install![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm having a possible problem with leak detection on my no-name chinese 8kW R32 air to water heatpump.
The manual says to pressure test with nitrogen at 45Bar (650 psi) ! I have a regulator that goes up to 50 bar so thats not a problem but pressure testing lines with such pressure seems completely bonkers. So i tested with 25bar (360psi) as i found r32 pressure is in the region of 20bar.
No leaks found. So then I wanted to pump down vacuum. I have a gauge built into my vacuum pump (and an automatic cutoff valve. Some 6mm ptfe line and 1/8th sae to barb on pump side and 6mm push in to 1/4 sae on pump side.
But the pump has schrader valves. High pressure can push through, but to pump down a stem has to be pushed in. I've inserted a 3in long piece of solid copper wire and made a loop in the hose to immobilise it. So when I push in the push in connector it presses the valve.
I pumped it down until the gauge needle sits on the stop and i left it for a bit. Upon return i discovered some tiny amount if air must be leaking through, but I'm unsure where from. In a span of 5 minutes the needle moves about 1mm up (where it initially says -1000mbar it moves to maybe -990mbar).
The question I have is. Is it likely i indeed have a leak in my lineset despite pressure testing with nitrogen? Or is the leak likely between the pump and its fittings and nitrogen testing at 25bar/360psi is better than vacuum?
