Before you ever connect a vacuum pump, you need to test for leak down with dry gas of some type. Welding gas, helium, CO2, whatever. Using compressed air is a bad idea, because humidity under pressure will bond with the copper lines themselves. You can remove the moisture, but it is difficult, requires multiple dry nitrogen purge/pressure/purge cycles, with vacuum pump oil change between each pull…
ESPECIALLY with a minisplit that has no desiccant dryer installed. And no, you can’t install a liquid dryer in the system, because, the lines do not have liquid flowing through them… BOTH lines are gas lines.
Minisplits are difficult to evacuate properly. Most only have a single port to evacuate, or charge through.
It is good you have a vacuum pump, but no, the retard section of the compound gauge is NOT sufficient to test for a good vacuum.
At 29.9inHg (the lowest pressure a vacuum gauge can report on earth) There are 10,000 microns of pressure still on the system… you need a micron gauge to report what the lines are evacuated to. And it needs to pull down to 500microns, and hold before you are sure there is no leak, or moisture in the system.
With a perfect leak free lineset, you will pull down to 500 microns in about 20 minutes. With a leaking line, you may never reach 500, and it’ll rise RAPIDLY over 1100 when the valves are closed.
Proper evacuation of a minisplit lineset instructions call for a triple vac/purge/vac to be considered acceptable.
