andy69morris
I am looking at adding additional panels onto my 2019 Cedar Creek 29RE Silverback 35' RV. New system will be four 400 watt panels separate from the current 400 watts already installed. Initially was going to space them out on the roof and not tilt them, Panels are 69X41, and was going to mount each panel cross-wise (69 with the width of the RV).
Thinking of raising them and mounting long ways (about 23 feet end to end just enough to clear vents tops and about 18" of the rear AC the rear (won't have any over the front AC which is my high point on the RV).
Looking at using aluminum struts to built and mount the structure to the roof by raising the strut off of the roof deck with 1/4" thick aluminum plates at roof connect points and then building a raise structure with strut material to clear the tops of the vents and rear AC) and running 2 parallel struts on the outside of each panel
Some concerns/advice
- Dissimilar metal corrosion, can't seem to find aluminum strut connectors, and brackets (zinc and galvanized are the only ones I have found.
- Hinges to mount each panel to the two struts running length wise (cross bracing in at least 5 spots, where panel meet and a start and end), with the possibility to be able to tilt each panel if needed. (a design a saw using hitch pins with a door hinge)
- 14 ga or 12 ga
See the attached PDF for my draft design so far.
- 14 ga or 12 ga
