nomadweb.design
- Dec 17, 2019
- 8
Hello, I have 2 X 100 watt Renogy solar panels that I am planning to mount to the top of my Promaster Van. Before mounting everything I am testing the equipment to make sure everything is working properly.
My setup
2 x 100 watt Renogy Solar panel *wired in parallel
100AH AGM weize battery
20a Renogy MMPT PG series charge controller
15 & 20 amp Fuses
10 AWG wire, branch connectors, all renogy parts
I just got the battery and it came charged, I also put the battery tender on it to top it off at 100%. Upon connecting it to the Rengoy MMPT it showed 100%.
It seems like when the battery is 100% and no load is on the system, the AMPs coming from the panels is dropped pretty low like around .25.
I tested putting a small fan on and the AMP input from the panels went to around 4.5amp. The panels are outside leaning on the van pointed at the sun and I would say it's not 100% ideal conditions but not bad. It is chilly out and it's early in the day.
I made a quick video showing the setup and the readings on the MMPT. You can see at the end of the video I turn off the Fan Load and the amps drop.
https://andrewmabry.com/solar.mp4
Just want to know if this seems normal and if I can proceed to mounting on the roof.
Thanks so much!!!
My setup
15 & 20 amp Fuses
Thanks so much!!!
