I built a 280ah battery last year for my van build which I recently found had started to leak electrolyte. I wasn't aware of it being necessary to have material between the cells other than for insulation (oops) and so two of them ended up chafing against each other. Electrolyte started leaking and thus damaged the laminate wrapping and blue casing.
Already ordered new cells but I'm now seeking some advice on what to use between the cells as well as what thickness of that material would be ok.
I saw a post here saying fr4 fiberglass sheets are the best option and have found some that are the right dimensions (although a few mm short of the width of each cell) except they are 1mm thick. The post I'm referring too said .5mm would suffice, so what thickness is too thick? I am worried about vibrations from driving causing some kind of wear on the cells again and so am considering putting rubber sheets between them maybe in addition to the fiberglass. I did order flexible busbars but since I don't have my cells yet I'm not sure as to what sort of gap I can get away with between the cells.
Some of the enclosure builds I've seen and have been referred to here have rods with compression springs on the ends. This is the post showing the compression rods, so if anyone has a how-to for that type of enclosure I'd appreciate it Not sure where to get those or how to build them exactly other than that its all-thread.
Would rubber be ok by itself as the material between cells? Would it help with vibrations over fr4? Worried about something rigid like fr4 causing chafing but maybe I'm being paranoid.
Thanks for any help.
