MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
What would be considered a safe time limit between the time your BMS shuts your LiFePo battery down with BMS set at 11.2v low volt disconnect at night after using to the time the sunrise begins recharging the battery back up?
I know it’s not a wise practice and can damage a LiFePo sitting at low voltage for a long time.
Does one need to immediately start recharge from shore power with a genny or other source?
Can it sit safely til morning sun?
