SlimyLemur56
- Feb 20, 2020
- 27
I have built a battery into a portable pelican (clone) case for a certain application. In this application there are a great many random parts involved and I have made painstaking effort to combine objects where possible to make packing and traveling and setup as easy as possible. I have a Lifepo4 charger I bought a while back which works fine, but I would really like to embed a charger into the case so that if I take it with me somewhere, I don't have to deal with an extra object (the charger) to keep track of. The hard case the battery is in is a very close fit, which is exactly what I want since portability is key, but it only leaves 1.5 inches (max) over the cells for circuitry like the BMS or anything else. The BMS fits nicely in this small space as does everything else except my charger is way too big.
Can anyone recommend a safe (preferably smart) charger that could fit in this small amount of space? If I need to have something with lower amps that is better than nothing, since I can always use my other charger if I need speed. 4amps or more would be nice since I could charge at roughly the same rate I drain it, replacing during the night what I use during the day. But even if 4 amps is not possible, it would be nice to have something in there so I can do some basic charging if I am traveling.
