Recommendation for a 370A BMS (or around 370A)
FreeFlyPR
Hi,
Im trying to figure out which BMS to buy for my 51.2kwh battery, it is a 16s1p (16) 1000ah Thunder Sky Winston, connected to (2) 12kw Sol-Ark inverters.
Sol-Ark 12Kw inverters max charge/discharge is 185A x 2= 370A
Im planning on using a Victron Smart Shunt and Solar-Assistant.
Also planing on using a 4A Heltec (or similar) Active Balancer with Bluetooth to balance cells from 3.4v and higher.
Preferably, I would like something with communication to the inverter.
Any info or recommendation, would be greatly appreciated!!
Thanks
Rad
For that that much current you probably want a BMS that can control an external contactor. Batrium, Orion, Chargery, QUCC. Probably others, that's what I can remember at the moment.
Hi,
Thanks
Rad
I am interested in this as well. I just saw these batteries and am wondering what kind of BMS coudl be used
