Have a unique situation. My main goal is track and log battery voltage on my PC. My batteries are UPS 2V and weigh 300lbs each. I have a main bank of 24 cells I run the house with. I have a spare set of 12 Batteries. This spare set I would like to charge full then us a BMS like a Daly LiFePo4 12s 36v 250A or a 30A unit if I cant charge.
I am trying to keep a max 2.30v to 2.35v over several days to try and equalize the cells. I have a lot of different voltages. I am also trying to identify bad and good cells. Kinda tricky to spot them. I was thinking if I can view all 12 cells or 24 cells I can see voltage out of wack. I would put a inverter on them and run a heavy load to spot bad cells.
1# How low can a Daly BMS go on voltage per cell. I need 2.25 to 2.35
2# Which BMS unit is best to view remotely on my PC?
3# I see the tiny wires on these BPM and cant imagine if can put to much power in a single battery. Is it a waste of time to get a 250A or 500A bms? Of if its not possible to charge I can get cheapest 30A BMS just to monitor.
Thanks for the help.
