Recommended vendors for GTIL inverters?
fafrd
Solar Wizard
I’m planning to pick up a couple of these budget 1000W current-limited GTIL inverters to time-Shift my solar production and there are a gazillion vendors on AliExpress.
Has anyone here purchased these GTIL products from a vendor they were happy with?
Is the root manufacturer behind all of these rebadged GTIL inverters known and do they have a store on AliExpress?
And finally, I think I’ve seen enough reviews to give these GTIL current-limited inverters a try, but is there any feedback from here on quality and/or value for money?
If these products are crap, is there an alternative budget product that is better?
Just Discovered that one of the Amazon vendors ships from US stock and qualifies for Prime (meaning no-cost return for any reason for up to 60 days): https://www.amazon.com/gp/aw/d/B07GC53QBD?ref=ppx_pt2_mob_b_prod_image
$275 was close to the best price I could find with shipping from any of the no-name vendors on AliExpress so this was a no-brainer and I’ve ordered two that are arriving in time for Christmas :).
I ordered two 1000 watt version from aliexpress. After two month one has failed with grid error , and 46.1Hz error, two resistors burnt out. Aliexpress determined that I deserve a $40 refund. based on that the display still lights up and that I did not show that we have actually 60 Hz in the US.
Aliexpress customere service id offline and chat is under construction.
In my dispute I had requested them to ship another one or refund the cost price of one plus some shipping. Videos of test and problems were uploaded and images of teh burnt out resistor as well.
Emailing with the company seemed to be helpful in the beginning but now it has come to a standstill.
Proceed at your own risk.
Johan
Johan
Wow, bummer.
I actually bought 2 of the 1000W models off of Amazon but have not yet put them into service. I tested functionality in a test setup for several hours and they performed as expected, so I’m going to give them a try.
Was yours hooked up for 240V AC output or 120V AC output?
2000W model on US split phase, 2kw of panels at 60v, no battery. In service exactly 1 year. No problems.
Are you using limiters? If so can you explain your setup? The best I have seen is dual CT clamps in Parallel seems to be the answer with a small trim pot for calibration. Is this how you did it?
PV to combiner box w/ fuses & SPD run to 45-90/240v GTIL to 240v double pole 15a in panel. For the limiter, I cut the supplied CT wire and soldered two of those 100/50 blue ones off Amazon (https://amzn.to/2XpJktx) in series. The GTIL stays under load by a couple of percent nearly all the time. Using a Sense monitor to keep an eye on it from the AC side.
I used "GAIADEFENDER store" - super fast shipping & they've been perfect for months.
What country are you in? I'll be getting rid of my 2x1000W 24v units very soon.
Hey Nate,
I am Canadian Based.. Where are you located?
I have been looking at these GTIL inverters, but wondered if we have other options. I searched a long time on Aliexpress and found this interesting Deye grid inverter with optional limiter and wifi:https://www.aliexpress.com/item/4000618719583.html
I like the fact you can go well above 2000 watts and the efficiency seems very good.
Those seem like interesting units, but depending on your use case, they impose a few constraints that may prove problematic:
No ability to be powered off of a battery (so only useable to reduce / eliminate grid consumption during daylight hours - no time-shift capability).
Startup voltage: 120V. This pretty much means you cannot feed this with less than a 3S string of panels (with little margin for Vmp since it can’t drop below 33.3V per panel if you only have a 3S string).
A max of 3.6kW of panels leaves plenty of headroom for 3 panels but the maximum of 10A of PV input current will be problematic with any modern (powerful) PV panel…
The 160-300VAC operating range means this should work with US 220/240V single-phase output, but not with 110/120V (translating to some export on one leg most always).
The SUN GTILs will operate off of a 24V battery (1kW model) or a 48V battery (both 1kW and 2kW models) and two of them can be connected to the two different incoming legs (L1 and L2) to drive each 110/120V leg to zero consumption (so meter consumption is truly zero, even in the case that individual legs are being monitored).
And while the 2kW / 48V model would need a 2S string to deliver at least 48V, the 1kW / 24V model can run off of a 1S string.
Poor conversion efficiency as well as loud fan noise are my two gripes with the Sunpower GTILs and if Deye ever offered a 2kW or 3kW model that could run off of a 24V (or possibly even 48V) battery and deliver 110/120VAC output, I’d be all over it (assuming they deliver efficiency in excess of 95% and can reduce fan noise as a result - at least when delivering modest power levels).
In general, these GTIL inverters allow an easy way to offset power consumption using solar power during the day, but at least in my case, it is the capability to be paired with a battery and an SCC that is the use-case whee they really shine (time-shift).
+1 on above - they're for Solar Panels not batteries.
HOWEVER... the alternative is to use Grid tie micro inverters, you can use batteries as inputs on those & they're also readily available & compliant with local standards.
Down side is that they're typically only 300W or so. You can also use small power supply modules to limit the input power & throttle them from max
The 2000 watt GTIL can drive 120v split phase? I thought only the 1000 W can sync with 120VAC.
I agree with you about the 10A DC limit on the SUN inverter. That is really close on a series string, but I feel the higher MPPT will help with efficiency and keep the wiring simpler.
There seem to be an inordinate number of GTIL dying, with folks showing blown transistors. That's why I'm looking for other options.
Here's another interesting option from Aliexpress: https://www.aliexpress.com/item/1005001565429387.html The inverter efficiency is awful, however, much like the GTIL that most use. 5-10% losses ends up being a lot of heat.
Probably works, but mercy, a lot of work for such a small amount of power. Plus, not cheap unless you have spare microinverters.
They are single-phase and can deliver down to 110/120V. By connecting one unit to L1 & N and another unit to L2 and N, you are independently compensating each hot leg (including 240V consumption for an electric oven, for example.
They are not strictly speaking ‘split phase’ because their is no communication or coordination between the two units.
The coordination is from the face that the grid delivers a 240W 2-phase power signal in which L1 and L2 are 180 degrees out of phase…
My 335W panels from 2016 exceed 10A @ 25C. Hopefully it’s just a throttle on maximum incoming PV current so you don’t need to be concerned with worst-case conditions, but it will translate to any modern high-power panels being driven at voltages higher than Vmp (whatever voltage throttles output current back to 10A).
Wire size can be smaller but you may be losing 10% of your available energy (or more).
Would love to see a link to any of those ‘blown transistor’ stories if easy. Many of the YouTube videos show people hooking these GTILs up in ways other than they have instructed.
That is the first generation of these same GTIL inverters (G1 versus G2). They require an ‘external’ sensor (separate small box) versus G2 which supports either a ‘external’ sensor or an ‘internal’ sensor (meaning just a CT clamp sensor wired to the GTIL).
I was under the impression that conversion efficiency of G1and G2 was similar. I’m getting ~80% efficiency but that is partly because I am operating at 24V (efficiency is higher at 48V).
Even with 20% losses, I’ve noticed surprisingly little heat. The fan kicks in often and strongly, so that’s my only gripe (it’s very loud).
For $250 each, I’m comfortable testing these for a couple years before investing $1000s in whatever my long-term inverter solution will be.
Are you positive the 2000 watt model can run 120VAC? All listings for 2000W version are shown for 180-260VAC, whereas 1000W is listed for 100-140VAC. Folks running the 2000 Watt model run 2 CTs in series or parallel, it would seem.
Go to "Solar Grid Tie Inverter with Limiter USA Users" Facebook group for plenty of posts about GTIL failures. Some guys have been running them for well over a year. Others get a few months. One way to hedge reliability issues is to get the 3 or 4 year extended warranty on a GTIL purchased from Amazon, or get the Square Trade warranty on GTILs from eBay. For the price, I really don't expect something reliable or well-built. If it costs $275 here, the actual parts value in the inverter has to be very low. As long as no one expects several years of service, I don't think one would be disappointed.
For simplicity, I would love to get a 2000 watt model that would sync with 120VAC. Running off a battery would be a plus.
I just checked my G2 manual and where the first 3 ‘connecting methods’ show 3 different ways of connecting a SUN-2000G2 for 240V output, the 4th method showing split phase output states ‘Using two SUN-1000G2 inverters to connect with US split-phase AC grid (good solution).
So it looks like you are correct that the 2000W G2GTIL does not support 110/120V output (and don’t you love how they use a combined manual for two fundamentally different products ;).
Not a Facebook guy, but thanks.
I’ve got a 4kW Microinverter-based grid-tied system as well. I have dual-Microinverters from NEP (Japanese Company) that cost me a little over $200 each and they have run reliably for over 5 years now.
Those microinverters only put out 600W rather than 1000W but my point is that low-power inverters can/must deliver good reliability and lifetime for low $100s of cost.
Whether these early-generation GTILs from China can deliver NEP-like levels of quality and lifetime is unlikely, but those products will materialize eventually.
My plan has been to set up a small 1kW GTIL system to learn and gain experience before investing in a larger 4kW DC-coupled system in 2-3 years (tied to getting an EV).
If these little 1000W GTILs conk out by then, no biggie and either there will be higher-quality GTILs in the marketplace by then or I’ll fall back to a split-phase hybrid inverter (many now ready for prime-time, but at much higher cost).
The cost savings from not having to do any AC rewiring with these GTILs is a major advantage (‘plugs in like a toaster oven’).
The manual is quite clear on the different ways to wire up these GTILs and many/most of the YouTube videos I have seen have involved splicing together 2 CT sensors in an attempt to avoid 240VAC export with a single GTIL inverter. They are not designed to do that and so any Facebook ‘failures’ associated with that bushwhacked wiring/configuration I would take with a large grain of salt…
Two 1000W 120V GTILs can be paralleled to deliver 2000W of generation capability.
So 4 1000W GTILs can be configured in a 2x2 configuration to offset a full 4kW of 240V AC consumption or up to 2kW of consumption on either leg.
My fridges consume half our annual power and never consume more than 600W after startup surge, so I’d really get no benefit from higher output levels.
When the electric oven is heating, that burns 1.5kW per leg and my pair of 1kW GTILs max out at ~850W each meaning they are only compensating 57% of consumption and the remaining 43% is being drawn from the grid, but that is only during the short time the element is being fired (low duty cycle after reaching target temp) and only for ~1 hour a couple times a week.
120V support is critical for the US market and from my perspective, it’s far more important to support battery-powered operation (and hopefully for less of an efficiency hit) than it is to support increased output levels.
If they crap out on me in less than two years, that will be my biggest complaint, but until that happens, it is how loud these little GTILs are that is my biggest gripe…
I believe I finally found proof that these small blue SUN 1000W and 2000W GTIL inverters are actually manufactured by Deye: https://www.solartex.co/tienda/wp-content/uploads/2019/02/FICHA-TECNICA-INVERSOR-CON-LIMITADOR.pdf
I’ve had mine up and running for over a month now and so far I am very happy with the quality and the performance (though I understand it’s still early days).
My only two complaints:
-poor conversion efficiency of ~80%
-they are loud when they need to activate the fans to stay cool
In addition to Solartex flyer, here is more evidence that the SUN-1000/2000G2 inverters are manufactured by Deye: https://www.google.com/amp/s/m.made...verter-Inverter-SUN-1000G2-LCD-777088335.html
I purchased mine from the Y&H store on Amazon: https://www.amazon.com/Inverter-Lim...ocphy=9032080&hvtargid=pla-523294429130&psc=1
I picked mine up on sale for $250 each over the Christmas Holiday Season but that was pre-inflation…
Unless the savings purchasing through a place like AliExpress is extreme (meaning ~50%), I’d recommend anyone interested in these little GTIL inverters to purchase through Amazon so you have over a mont to test the unit out and return it if you are not satisfied.
If you are going to be powering with a battery, you need a 24V or 48V battery before you can run a test, but here is how I did a very quick test to comfort myself that the unit performed as advertised:
1/ get an old extension cord and cut away a portion of sheathing so that you can get the CT sensor around the black (hot) wire.
2/ connect the GTIL inverter to your battery, connect the CT sensor (already on the hot wire) to the inverter and plug some load into one output of the extension cord (I used a space heater).
3/ now power up inverter by plugging it into another outlet of the same extension cord. You will see it turn on, it will indicate battery voltage and AC power being sensed (which should be positive or you’ll need to flip the CT sensor) and the AC output which will be 0W. And then after a short delay, you’ll hear the inverter start inverting (increased buzz/hum) and you’ll see the AC power output increase to some number of Watts close to the power draw of whatever appliance you’re powering, and you’ll see the AC power being sensed drop to 10-20W.
This is all assuming you’ve properly configured the unit for limited inverting. You can start by setting a hard limit below the consumption of you appliance to assure you are not exporting and activate the CT sensor limit function after the unit has started operating and you are comfortable everything else is in order.
You will need some way to validate that net power export is what the unit is reporting. I have a clamp-style multimeter and had enough wire exposed to clamp it next to the CT sensor so that I could verify the 10-20W net consumption being reported by the inverter.
After seeing so many reports of the SUN-1000G2 needing at least a 36V battery for battery operation, I was very concerned about whether the unit would work with my 24V battery.
Operating DC voltage range is 22-65V and I used a voltage supply to confirm my units had no issues operating down to DC voltage of 22.0 (delivered to the input lugs, so you need to properly account for voltage drop on the supply wiring).
The ‘Startup Voltage’ is specified as 25V, but my units had no issues starting up at lower DC voltage of as low as 22.2V.
So I’ve had no issues running these units off of a 24V LiFePO4 battery and suspect that enough customers trying the configuration didn’t understand how to properly size supply wires that Deye/Y&H decided the hassle of trying to support those unhappy customers was not worth it and specified a minimum of 36V for battery operation instead.
I’m using dedicate 2/0 welder’s cables to supply each of my 1000W GTILs and even at maxed-out current levels of 40A each, voltage drop from battery terminals to inverter input is less than 25mV.
So my recap is that these SUN-1000/2000G2s work fine off of 24V batteries (despite statements and specifications to the contrary) but you need to err on the side of overcabling if you want to go that route…
So running these with batteries you still need a charge controller? What are you using or am I not understanding?
Yes, that’s correct. These GTILs include an MPPT and can be powered directly from PV, but unless your load exceeds PV production all day long, that means you will be wasting some of your solar power.
In my case, the utility has greatly reduced the value/credit of production or reduced consumption during daylight hours and greatly increased the cost of evening consumption (4pm to 10pm).
So my primary goal was ‘time-shifting’ and I made a 560Ah 24V LiFePO4 battery for that purpose. Since the battery is connected to the DC power inputs of the GTILs (meaning MPPT voltage is clamped to battery voltage), I need a separate ‘box’ to get my battery charged from my solar array.
I purchased an Epever 6420AN SCC connected to my 1.1kW DC-coupled array to charge the battery during daylight hours (when electricity here in California is ‘worth’ $0.20/kWh).
A ‘bonus’ I had not expected in the AN-Series SCCs is that they contain two programmable dry contacts including one that can be controlled by an internal timer.
So I’ve used a cheap 2-pole relay controlled by the Epever’s dry contact to ‘connect’ AC power to my two GTILs only when Peak Period starts at 4pm.
The GTILs both turn on and offset consumption only during peak period, meaning they are reducing my electric bill by $0.45 for each kW of power they put out.
In summer months of June-September when Peak pricing is applied, I’m generally charging well more that the kWs of energy every day to offset nearly all of my peak consumption (when the Electroc Ovwm Element is firing, that 3kW load exceeds the maximum power of ~1.6kW that can be put out by the GTILs, so only ~53% of that consumption is being offset by the GTILs and the rest is being supplied by the grid).
Because the dry contact of the Epever can be programmed both by time and battery voltage, I have it programmed to run from start time of 4pm until the battery is empty. This means I maximize the self-consumption I offset at peak rates of $0.45/kWh but then continue offsetting consumption at off-peak rates of $0.20/kWh until the battery is drained and ready to begin charging again the next morning.
After first building my 24V battery top-balanced, I quickly figured out that a bottom-balanced battery would actually be better-suited for this application.
I spent $500 for the 2 1kW GTILs and another $240 for the 1.5kW Epever SCC and overall, I’m exceedingly pleased at how that sub-$750s-worth of electronics is performing.
Right now I’m only generating about 1140kWh / year with this rig because that’s all the self-consumption I have to offset, but it’s been designed so that once we get an EV, I can add another 400-500W panel to cover 1300-1700 miles of driving each year or more panels + a second SCC if we drive much more than that (I’ve already wired-in 3 string home-runs total).
fafrd:
I have to laugh every time I read one of your posts about these GTIL units. You are obviously enamored with them, and personally, I'm glad that you go to the trouble to share your experiences. I'm with you on your hope that someone like Deye will make a better quality version in the future.
What makes me laugh are your comments about avoiding rewiring your loads. I'm not picking on you, and I also have no idea of how your property is built, or how the wiring is done. That being said, I've rewired dozens of services, and it just isn't that big of a deal. Especially when someone is talking about a critical loads panel. AC current is way easier to deal with than DC, and in comparison, is almost childs play.
In most cases, you can simply install the new panel adjacent to the older (main) panel, commonly with just a pipe nipple and some insulated bushings. Move a couple circuits over to the new panel, and put your breaker in the other panel if using it as a sub-panel. If wires are not long enough, mount a junction box, and splice the wires to extend them. I've had numerous people ask if that is going to affect anything. They don't seem to realize that your outlets are already wired point to point. Just make good connections, and put them in a properly size junction box.
A good friend of mine who was always paranoid about any wire connection would crimp the wires. Not a bad idea, but hard to deal with if you every have to change anything. I've seen many, many inspected systems where an electrician used the original service as a large junction box, and put plugs in any holes that were not being used. Sometimes, they cut a piece of tin and make a new cover for the old box.
Again, not picking on you. But I see this same comment over and over on this forum, and it amazes me that people will build their own battery banks, deal with all sort of hardware and software issues for DC, solar, etc, and yet be afraid or unwilling to mount a circuit panel for simple ac. By the way, when we move to a new area, I always check with the local permit folk, get approved to do my own work, and take out permits. It isn't hard.
So, please, carry on with the GTIL stuff. I'm interested in trying one myself, just for fun.
As I consider the Amazon Y&L 1000W Grid Tie w Power Limiter: Question: Do you know : Can that "power limiter" block all grid feeding? like: Can the whole unit w power limiter be configured to send all solar conversion of 120vac to home load only? while blocking all excess above home load from grid feeding? ... even for a minute??? ... I am considering this unit for a Costa Rica experiment on a highly valued grid connect going through an old type mechanical meter that gets physically read once per month. ... If I experiment, it would be without going legal (while also doubting while wondering / this unit could make a legal hoop jump in Costa). I do not want to risk my meter connection. Costa Rica does have a route for legal grid ties. I am considering the gorilla option for just covering some smallish electric needs, like for an Air Conditioner unit; and showing some of my solar interested neighbors some options. ... Also Wondering: Can these type of units be legally hooked up to the grid some places in the world, in an above board way? ... I would welcome info. for my understanding that part of the world view picture . Bet it is no big deal in some places outside the usa.
fafrd:
What makes me laugh are your comments about avoiding rewiring your loads. I'm not picking on you, and I also have no idea of how your property is built, or how the wiring is done. That being said, I've rewired dozens of services, and it just isn't that big of a deal. Especially when someone is talking about a critical loads panel. [b[AC current is way easier to deal with than DC, and in comparison, is almost childs play.[/b]
Agree, in general.
Yes.
Not paranoid, lazy (and no space).
Been there. Done that (with my home’s original service which is a 6-fuse block seeing knob and tube wiring).
The electrical system of my 1940’s era home is essentially maxed out in terms of available physical space for panels as well as in terms of how far the existing wiring can be modified / extended.
Not impossible to upgrade everything but a lot of work and expense.
Not afraid, certainly unwilling until there is no alternative. I drew up the plans, got all the permits, and did all the install for my 4kW AC-coupled system (which is where I experienced the joy of converting the original service main, by then a subpanel with fuses, to a junction box :). I know exactly what my inspector thinks of my home wiring and what changes he’d require for any rewiring of my circuits.
We’re considering remodeling the kitchen and a project like that would likely require reworking the entire service entrance. When that day comes, it’ll be straightforward to also organize either the entire main panel as a critical loads panel with transfer switches to the main breaker or a portion of the home’s circuits in a critical loads subpanel…
But that day is not this day (partly because backup power is not a priority now, just time-shift to offset the impact of rate changes).
So, please, carry on with the GTIL stuff.[b[ I'm interested in trying one myself, just for fun.[/b]
You’ll get a kick out of it when you do. They are a true innovation that has been widely under appreciated by the market.
I’m watching to see whether ‘zero-export-to-CT’ and parallel connection configuration gets UL listing and approval by building departments.
For now, I’m just playing around, learning, and offsetting my rate increase in advance of my larger, more permanent build expected in 2023 when we expect to get an EV (and may also remodel our kitchen ;)).
