In addition to Solartex flyer, here is more evidence that the SUN-1000/2000G2 inverters are manufactured by Deye:
https://www.google.com/amp/s/m.made...verter-Inverter-SUN-1000G2-LCD-777088335.html
I purchased mine from the Y&H store on Amazon:
https://www.amazon.com/Inverter-Lim...ocphy=9032080&hvtargid=pla-523294429130&psc=1
I picked mine up on sale for $250 each over the Christmas Holiday Season but that was pre-inflation…
Unless the savings purchasing through a place like AliExpress is extreme (meaning ~50%), I’d recommend anyone interested in these little GTIL inverters to purchase through Amazon so you have over a mont to test the unit out and return it if you are not satisfied.
If you are going to be powering with a battery, you need a 24V or 48V battery before you can run a test, but here is how I did a very quick test to comfort myself that the unit performed as advertised:
1/ get an old extension cord and cut away a portion of sheathing so that you can get the CT sensor around the black (hot) wire.
2/ connect the GTIL inverter to your battery, connect the CT sensor (already on the hot wire) to the inverter and plug some load into one output of the extension cord (I used a space heater).
3/ now power up inverter by plugging it into another outlet of the same extension cord. You will see it turn on, it will indicate battery voltage and AC power being sensed (which should be positive or you’ll need to flip the CT sensor) and the AC output which will be 0W. And then after a short delay, you’ll hear the inverter start inverting (increased buzz/hum) and you’ll see the AC power output increase to some number of Watts close to the power draw of whatever appliance you’re powering, and you’ll see the AC power being sensed drop to 10-20W.
This is all assuming you’ve properly configured the unit for limited inverting. You can start by setting a hard limit below the consumption of you appliance to assure you are not exporting and activate the CT sensor limit function after the unit has started operating and you are comfortable everything else is in order.
You will need some way to validate that net power export is what the unit is reporting. I have a clamp-style multimeter and had enough wire exposed to clamp it next to the CT sensor so that I could verify the 10-20W net consumption being reported by the inverter.
After seeing so many reports of the SUN-1000G2 needing at least a 36V battery for battery operation, I was very concerned about whether the unit would work with my 24V battery.
Operating DC voltage range is 22-65V and I used a voltage supply to confirm my units had no issues operating down to DC voltage of 22.0 (delivered to the input lugs, so you need to properly account for voltage drop on the supply wiring).
The ‘Startup Voltage’ is specified as 25V, but my units had no issues starting up at lower DC voltage of as low as 22.2V.
So I’ve had no issues running these units off of a 24V LiFePO4 battery and suspect that enough customers trying the configuration didn’t understand how to properly size supply wires that Deye/Y&H decided the hassle of trying to support those unhappy customers was not worth it and specified a minimum of 36V for battery operation instead.
I’m using dedicate 2/0 welder’s cables to supply each of my 1000W GTILs and even at maxed-out current levels of 40A each, voltage drop from battery terminals to inverter input is less than 25mV.
So my recap is that these SUN-1000/2000G2s work fine off of 24V batteries (despite statements and specifications to the contrary) but you need to err on the side of overcabling if you want to go that route…
