Cheap 4-life
My body is 2.63 trillion volts, .07v per cell
Same here, nothing but good things I can say about them. Using for 4 years
If I can get 4-years out of my 2 GTILs, I’ll be more than happy.Same here, nothing but good things I can say about them. Using for 4 years
They are powered by 60v batteries. I run my inverters 24/7. They ofcourse use solar directly from cc when there’s day time loads, but when there’s clouds solar batteries and maybe a little grid power could be used if my loads are over the 3500w capacity of the inverters, if it’s night time the batteries are utilized and maybe a little grid power.If I can get 4-years out of my 2 GTILs, I’ll be more than happy.
One of the hidden gems of the DIY world
Are you driving yours directly off of solar or from a battery?
I’m charging a 24V LiFePO from an SCC during daylight hours and running the GTILs off of that stored energy late into the night to offset peak consumption long after sunset… (time-shift).
Nice. I’m guessing you’re getting much better efficiency operating off of 60V batteries than the ~80% efficiency I get operating at 24V.They are powered by 60v batteries. I run my inverters 24/7. They ofcourse use solar directly from cc when there’s day time loads, but when there’s clouds solar batteries and maybe a little grid power could be used if my loads are over the 3500w capacity of the inverters, if it’s night time the batteries are utilized and maybe a little grid power.
Electric bill is near zero every month other than the service fee
I’ve calculated 86% efficiencyNice. I’m guessing you’re getting much better efficiency operating off of 60V batteries than the ~80% efficiency I get operating at 24V.
But if you’ve gotten 4 years operating 24/7, that hopefully bodes well for the longevity I’ll get operating less than 12 hours per day .
Cool - that’s not nearly enough of a gain to get me to ditch my 24V battery and 1S3P array for a 48V battery and 3S1P array (my little 1kW DC-coupled array suffers from severe shifting shade issues throughout morning, which have been very nicely mitigated by using half-cut panels in a parallel array…I’ve calculated 86% efficiency
Have you joined the GTIL2 Facebook group? Solar grid tie inverters with limiter USA users? I am the moderator thereCool - that’s not nearly enough of a gain to get me to ditch my 24V battery and 1S3P array for a 48V battery and 3S1P array (my little 1kW DC-coupled array suffers from severe shifting shade issues throughout morning, which have been very nicely mitigated by using half-cut panels in a parallel array…
If I went to a 3S1P array and a 48V battery, I’d probably lose more is reduced energy capture than the ~7.5% increased output I could get from the same stored battery energy.
Sorry for not seeing this until now, it I’m not a fan of Facebook.Have you joined the GTIL2 Facebook group? Solar grid tie inverters with limiter USA users? I am the moderator there
There’s a lot of info regarding these inverters there.
Using a 24v battery forbthese inverters puts a lot of unneeded stress on them. I recommend a minimum of a 36v battery for the 22-65v version.
I only use Facebook to learn stuff and help others..Sorry for not seeing this until now, it I’m not a fan of Facebook.
At this point, I’m stuck running my GTILs at 24V.
With smaller cables, a 24V battery can certainly be a challenge, but I used 2/0 welders cables and have had no issues (for one year now).
I may eventually go to 48V but only if I add Microinverters to my backup power array along with a proper hybrid inverter…
I use the CT sensors and I’d been working great, but my offset level is typically low (25 to 250W).I only use Facebook to learn stuff and help others..
If you are limiting the inverters amps it can use in its settings then that slightly helps mitigate some of the concern of using such a low voltage..
The size of the cables do not matter in regards to what I’m saying.. it’s how many amps your making the inverter use compared to the lower amps it would use if you were supplying it with a higher voltage.. if the load is 800w and your supplying the inverter with 48v then inverter only has to use 16amps. For that same 800w load and instead 24v battery the inverter has to use double the amps at 32amps.. more amps is more heat and more stress. Also 32amps is real close to the max the inverter can handle. 48v though is actually to high. That high of a voltage can stress the components because the voltage is at the inverters components max range.. this is why the best battery voltage is 36v for these cheapo 22-65v GTIL2s for longest life..I use the CT sensors and I’d been working great, but my offset level is typically low (25 to 250W).
What issues have others reported when running off of 24V batteries and are they using battery cables as large as mine (2/0)?
Heat is related to power, not current. 16A x 48V = 768W = 32A x 24V…more amps is more heat and more stress.
These inverters are rated for 1000W of input power. That translates to 20.83A @ 48V or 41.67A @ 24V.Also 32amps is real close to the max the inverter can handle.
36V is a difficult voltage to manage, but I am interested to know whether you have any efficiency data from GTIL owners operating at 36V…. If 90% or higher that could represent a significant drop in internal energy loss and heat geberation.48v though is actually to high. That high of a voltage can stress the components because the voltage is at the inverters components max range.. this is why the best battery voltage is 36v for these cheapo 22-65v GTIL2s for longest life..
I’m not expecting to get very long life from these very cheap inverters (I paid $275 for mine) but I am interested if you have any details from those who experienced failures @ 24V.Issues reported are damage to these inverters/destroying them by over working them due to a 24v (to low voltage) battery..
We’ll I suppose I’ll be a reality check on your hypothesis then.the only way to get long life out of these inverters with a 24v battery is to set the amp limit to no more than 25amps in the settings.. still not good to use such a low voltage battery for these inverters but setting the amp limit will help..
less amps means less heat to make the same power. For example this is part of the reason why electric companies send out power at 17k volts. Smaller wires less amps less heat etc etcHeat is related to power, not current. 16A x 48V = 768W = 32A x 24V…
This stuff isn’t up for debate.. I know what these inverters are rated for lol.. you can continue to use whichever battery voltage you choose.. even Rogel (creator) has said its best to use a higher voltage than 24v for these inverters..These inverters are rated for 1000W of input power. That translates to 20.83A @ 48V or 41.67A @ 24V.
Efficiency is also better due to less heat in the inverter due to higher voltage.. heat is wasted power..Efficiency is supposedly higher at higher voltage, presumably meaning that you will get more maximum power output from 20.83A@48V than you will than the ~800W I am getting from 41.67A @ 24V (~80% efficiency).
For efficiency alone, no it’s not worth the change to a higher voltage.. to not waste your money and not work your inverters so hard to make them have an early demise, it’s definitely worth changing to a higher voltage from the start.. the voltage of a battery bank should be what’s best for the inverters. Sounds to me that you had your battery before the inverter..But I’m hearing from other GTIL owners operating at 48V that they are getting efficiencies of ~85%, and for 25% less internal heat generation, I’m not sure the change is worth it…
Again it’s not about efficiency. It’s about destroying these cheap inverters by overworking them. At 24v they are basically screaming for higher voltage. It doesn’t make sense to work cheap inverters as hard as you can by supplying them with the lowest voltage they can possibly use.36V is a difficult voltage to manage, but I am interested to know whether you have any efficiency data from GTIL owners operating at 36V…. If 90% or higher that could represent a significant drop in internal energy loss and heat geberation.
I am expecting to get a long life out of mine and many others have and I’m explaining to you how to do it. The details are on the Facebook forum of which I have had many extensive conversations with many of our members regarding using a 24v battery with these inverters. It is in the announcements not to use a 24v battery for these inverters. Rogel has his own Facebook group for these inverters, mostly foreign language.. if you have never read anything on any of these groups (mine or Rogels) then you probably shouldn’t be questioning my advice so much. There’s a plethora of information to help users use these inverters correctly on those forums.. I myself have read days and days of issues problems advice etc etc.. and have helped many figure out their problems as a lot of these inverters are installed DIY by people who do not know what they are doing. I’m a licensed electrician and have installed many solar setups..I’m not expecting to get very long life from these very cheap inverters (I paid $275 for mine) but I am interested if you have any details from those who experienced failures @ 24V.
As I wrote earlier, my average load is very modest (25W to 250W) in case operating near maximum output levels was a contributing factor to those component failures @ 24V.
The only time my GTILs max out is on those rare times we use the electric oven and even then, it’s typically under 25% duty cycle after the oven has heated up to temp…
Hypothesis it is not. Everything I’m saying has been proven many times over..We’ll I suppose I’ll be a reality check on your hypothesis then.
I am using a 60v battery and using two of the 2kw inverters in the USA. for a 36v battery most bms and charge controllers can be used..so I’m interested to understand what BMS and charger you are using for your 36V battery.
Many users of these inverters are using a 36v battery. I use the 45-90v inverters so I use a 60v battery for the same reasons a 36v battery should be used for the 22-65v inverter.. higher voltage is easier on the inverters..So going 36V / nonstandard might eventually be an option for me and if you’ve already headed down that path, I’m interested to learn more…
you may not think it’s up for debate, but that doesn’t mean you understand the underlying physics.less amps means less heat to make the same power. For example this is part of the reason why electric companies send out power at 17k volts. Smaller wires less amps less heat etc etc
I’m not arguing that lower voltage is better. My point is that if you plan for it appropriately (by using much lower-resistance battery cables), he difference in performance between 24V operation and 48V operation is less than you are suggesting it is.I know what these inverters are rated for lol.. you can continue to use whichever battery voltage you choose.. even Rogel (creator) has said its best to use a higher voltage than 24v for these inverters..
Internal to the inverter, I agree. Those wires are all remaining the same size, so wire-related loses internal to the inverter should be 300% higher when powered at 24V compared to when powered at 48V..Efficiency is also better due to less heat in the inverter due to higher voltage.. heat is wasted power..
As I said from the outset, I’ve been constrained to a 24V battery because of my need to charge with a 1S solar array (severe shading).For efficiency alone, no it’s not worth the change to a higher voltage.. to not waste your money and not work your inverters so hard to make them have an early demise, it’s definitely worth changing to a higher voltage from the start.. the voltage of a battery bank should be what’s best for the inverters. Sounds to me that you had your battery before the inverter..
Once again, I’m driving my GTILs with relatively modest loads of 25W on one and 250W on the other, not ‘as hard as I can.’Again it’s not about efficiency. It’s about destroying these cheap inverters by overworking them. At 24v they are basically screaming for higher voltage. It doesn’t make sense to work cheap inverters as hard as you can by supplying them with the lowest voltage they can possibly use.
Yes, I know that. And yet, with testing, you can discover exactly how these GTIL inverters perform powered by a 24V battery.I am expecting to get a long life out of mine and many others have and I’m explaining to you how to do it. The details are on the Facebook forum of which I have had many extensive conversations with many of our members regarding using a 24v battery with these inverters. It is in the announcements not to use a 24v battery for these inverters.
I’m not questioning your advice, I’m explaining the reasons I don’t believe it necessarily applies to my situation:Rogel has his own Facebook group for these inverters, mostly foreign language.. if you have never read anything on any of these groups (mine or Rogels) then you probably shouldn’t be questioning my advice so much.
I’ve read enough of the horror/failure stories from various places to know you are correct about that, and those un knowledgeable DIYers are lucky to have you helping them, but I am not one of them.There’s a plethora of information to help users use these inverters correctly on those forums.. I myself have read days and days of issues problems advice etc etc.. and have helped many figure out their problems as a lot of these inverters are installed DIY by people who do not know what they are doing. I’m a licensed electrician and have installed many solar setups..
At least on this point, we seem to agree…If your loads are only 250w then that’s why your inverter has made it as long as it has at 24v.. the inverter simply isn’t using many amps with load that low.
If you know of anyone else who has powered their GTIL from a 24V battery using short 2/0 battery cables, I’m all ears.But when the ovens on it does and that’s why you need to set an amp limit to 25amps in the settings...
Ah, so you are using the 2kW model. What BMS and charger are you using for your 60V battery? How many LiFePO4 cells make up that battery?I am using a 60v battery and using two of the 2kw inverters in the USA.
I’ve seen that some BMSes allow you to just not use some of the leads, but my biggest concern is with mainstream hybrid inverters.for a 36v battery most bms and charge controllers can be used..
I certainly agree that it’ll be easier to get these GTILs performing correctly with 36V or 48V batteries than with 24V batteries.Many users of these inverters are using a 36v battery. I use the 45-90v inverters so I use a 60v battery for the same reasons a 36v battery should be used for the 22-65v inverter.. higher voltage is easier on the inverters..
I appreciate the advice but a Facegroup forum full of unknowledgeable DIYers is just not my cup of tea.I am typing all this for like the millionth time so some of it might sound a bit like an attitude... is all in the announcements on the Facebook group... search solar grid tie inverters with limiters USA users
You may be misunderstanding what I’m saying.. 24v 32amps creates more heat inside the inverter (not in wires outside the inverter) than 48v 16amps .. that’s why these inverters (the 22-65v version) using a 36v battery causes less heat because the inverter is using less amps.. the more amps an inverter uses, the harder it’s being used the more stress it is going thruCurrent and amps don’t generate hear, power and watts do.
If the ~80% efficiency I’m getting @ 24V was primarily caused by increase interval wiring losses, efficiency @ 48V should be ~95%.
Well unfortunately you are wrong because these inverters should not be used with a 24v battery to prolong their life.. if you don’t care about longevity or your loads are always extremely low then of course using a 24v battery would be ok but you would be barely using the inverter so of course it would last long. Yeah they say you can use a 24v battery because 22v is the low end but they also say you can plug these inverters into an outlet which should absolutely be avoided as anyone who knows what they are talking about would do..I had to look long and hard to find an inverter that could operate at 24V and the GTILs fit the bill (with a bit of attention to wiring).
I’d love to what lifetime anyone who used a similar setup to mine got out of their GTIL and how it failed.
And from that vast number of failures you are aware of at 24V, I’d also love to know how quickly you believe my more heavily-loaded GTIL running 12 hours out of 24 @ 250W should be expected to last before it conks out.
