Solarfun4jim
Solar seduced :-)
Can a 240vAC(13A UK plug supply) circuit be switched using a continuous duty NO contactor with a 12vdc 0.8A 'control circuit' and rated at say 400A on the load side.
If not, why not exactly? If it is simply a switch and the DC control side is a seperate circuit from the AC load side, why do i keep hearing that it is a problem? Surely a switch rated to handle 400A dc would easily handle 13A ac for example. What is it about AC that would be an issue for the contact?
