edgecrusher
- Jan 8, 2022
- 42
Good Day All:
Looking for some advice/experience.
I am early in planning an install that would utilize either a Sol-Ark or Luxpower inverter (both seem to meet Canadian code). One (of many) challenges I am facing is that I want to mount this inverter/batteries/solar away from the main house, in a power shed.
My mains are 240v split phase, and 200A. The power shed is ~75m (250') from the house. I'm planning on running ~150A feed from the main panel to the power shed, then back to a critical loads panel in the house. Since the distance is quite long, I highly doubt I can run the CT's mounted to the utility feed the 250' to the power shed, especially along the same route as the buried AC.
I see that with the LuxPower, I could potentially install a SDM630 meter (assume I can use the CT version), and then modbus back to the power shed. I don't believe that Sol-Ark has this capability.
Goal here is zero-export, but I would like to be able to offset loads NOT on the critical panel when I have excess solar/battery during peak.
Any experience, thoughts, ideas?
