Could a 300W solar panel remove 5 liters of CO2 from the atmosphere per day?
3.5% of seawater is "salts", of which Calcium ions are 1.2% and Magnesium 3.6% (both of which can sequester CO₂). Aqueous CO₂ is around 100 mg per liter of seawater (
ref).
...Looks like [centrfiguing CO₂ from seawater] possible, but not energy efficient ...
From this
ref, looks like 500 W/m³ would be state-of-the-art.
As there are 1000 liters per cubic meter, from the above
100 mg / l x 1000 l/m³ / 1000 mg/g = 100 grams / m³
2 m³ / kW, that would be 200 grams CO₂/kW.
That assumes 100% efficiency, which isn't likely. But, also dissolved into seawater is carbonate (that causes the acidification damaging to reefs), as the aqueous CO₂ is removed, the carbonate should shift into aqueous form. So, it might be possible to be over 100%.
Those back-of-the-envelope calculations ignore the thermodynamic effects and assume separation is achievable at 5200 rpm @ 500W/m³, which is completely unknown to me and probably bogus. There are also other possibilities, for example, some solar heating of the water before separation should improve the yield (most gases are less soluble as temperature increases). Similarly, both calcium and magnesium are less soluble and more likely to bind to CO₂ at lower temperatures. So it might be more/less efficient either way.
One
study says 274 kg of CO₂ is created per kW of panel produced/delivered. 137 Kg of Coal would produce about 274 kg of CO₂ and 0.5MWh of power. Over its life, a kW solar panel would produce 40 to 60 MWh. So solar is better than coal in terms of energy to CO₂.
But in terms of CO₂ removal via a centrifuge, the numbers aren't so friendly. If any of the math above is correct (very unlikely), such a panel would have to run for 75 years just to break even. So, this technique to remove CO2 from the atmosphere seems like a bust.
