Hi All,
I need to remove my solar panels (30 in total) from my roof. Obviously, safety is my #1 concern, so I wanted to run my plan past the fine folks on this forum before proceeding to see if anyone has any words of wisdom. I have a grid tie system with two Fronius Primo inverters, and 30 panels. The configuration is:
1. Rooftop Combiner
2. Inverters
3. PV Breaker Panel
4. DG System Disconnect (Two power source parallel system)
5. Generator Meter/ 6. Load Meter ===> 7. To Hydro Utility Transformer
My plan is to:
1) Turn off the DG System Disconnect with the big switch next to the Generator Meter
2) Turn off the two fuses inside my garage which connect to the two inverters (the fuses sit between the inverters and the DG System Disconnect)
3) There are knobs on the bottom of both the Fronius Inverters which I will turn off.
4) Go on the roof and cover the panels with an opaque material / perform the work during a low light time.
1. Rooftop Combiner
2. Inverters
3. PV Breaker Panel
My plan is to:
