does it take all the amperage from the solar, and then cut down on the alternator side, or is it always a 50/50 split, 25a/25a, when the alternator is charging ?? i
This is the most-misunderstood aspect of the charger. The dispositive section of the manual:
seems all i read here that this gizmo is not that popular ?
I'd guess it's the most popular DC-DC/MPPT combo since its release. It has one significant limitation (25v PV input) and a couple useful features rare in other units of this type (low temp cutoff in Li profile, battery voltage sensing option).
It is great sport here on the forum to bash Renogy, which IMO says more about the bashers than it does about Renogy. All the Renogy gear I've had hands on, including the DSCC50S, worked as designed.
Before Renogy the Ctek setup was the most popular. The Kisae is gaining mindshare. I imagine Redarc dominates in Australia. SRNE has released a 50A that looks promising; like the Kisae but with mixed solar/alt modes, voltage sense wire terminal, and a terminal that accepts a signal to stop charging - the latter could be used with a temp switch to disable charging in cold weather.
so what could i use instead to be able to use both alternator and solar on my new 350 Transit ?
There are
many combo units out there, but it's probably more common to use separate solar charge controller and alternator-based chargers. More control, typically better spect, not a single point of failure.
mounting it on the outside of the van compartment would be a better thing ??
I don't know what a van compartment is. Chargers like this are typically mounted as close to the battery bank as possible; consult the manual for specifics.
so u think 400w of solar panels would be good for this and a 206ah SOK battery, or would 600w be better in the long run.
This depends on
your daily power requirements, when/where you are camping (solar harvest varies greatly by season and location), and how many hours you drive on average per day. I will say it is rare for people to wish they had
less panel.
