First one purchased last November ('22). Worked great for several months on several trips, often getting almost 50 amps out of the alternator. Usually would take a 4-5 day trip every other month.
Then in May all of a sudden I was only getting mid 30s on amps. And it went down from there on the next trip to about 18 amps.
Tow vehicle (TV) is a 2014 Ford Expedition with a 175 amp 'dumb' alternator. I have a 40' run from the TV starter battery to the DC to DC charger in the trailer using 4 gauge cable with an Anderson connector at the bumper.
After many hours with Renogy customer service (ahem...) their 2nd level US based customer service sent me a new unit. Right of the bat for a few minutes it was at 45 amps, then as driving progressed that day, we went to about 35 amp and it stayed there the rest of the trip.
I have done a bunch of testing of the battery and alternator, at one point showing the alternator putting out 135 amps on the cable that runs to the starter battery, with just about everything turned on that I could to make the alternator work hard. The battery is a couple of years old. Battery and alternator tests with my code reader show both as good. Auto parts testing for both shows the same. I can't find anything wrong so far except the amp dropping from the steady 45 amps or so that we had for several trip after installing the first charger.
Any educated thoughts would be helpful. If this is in the wrong place, please excuse me and move it. Thanks!
