McDavid403
- Oct 16, 2021
- 24
Hi, Does anyone have experience with the Renogy Rover Li 40 Amp MPPT Solar Charge Controller.
According to the manual, the MPPT charge controller should boost the current going from the panel to the battery so you don’t lose any power due to the stepped down voltage.
I have a Sunpower 100W panel hooked up to my renogy charge controller and a victron smart shunt between the battery negative terminal and charge controller output.
The charge controller is measuring 18.6V and 7.38 Amps at the panel but I am only seeing 7.26 Amps at 13.3V going into the battery. Would think the Amps going into the battery pack should be closer to 10 Amps?
