Repair a Relion 50aH LIFEPO4?
Had the above battery sitting in my inflatable tender, connected to a Victron MPPT controller, in turn charged by a small 50 Watt solar panel.
Left in boat, on dock. Forgot to take out the boat's bung. After a rainstorm the controller & battery were flooded. Victron controller was toast. Relion battery will no longer take a charge, assuming it's BMS is also toast.
Is there any point in dismantling the battery and testing the cells to see if they are still functioning; replacing the BMS? If yes any advice would be greatly appreciated please?
Cheers
Cheers
