skyking1
We have a power loveseat in the travel trailer. The battery can run it over a long weekend no problem when boondocking. This year it did not come back to life when we took it out. It passes through the juice and operates when plugged in, but no joy on charging it up. I took it apart and was greeted with that stink.
It is a 29V thing and a quick check showed 12 volts across the batteries.
A closer look and this cap seems smoked.
![PXL_20240724_231601206.jpg PXL_20240724_231601206.jpg](https://diysolarforum.com/data/attachments/230/230948-8bccf1d9ca74c04b111302de1ab0ca65.jpg)
The thing is like this:
![PXL_20240724_231615357.jpg PXL_20240724_231615357.jpg](https://diysolarforum.com/data/attachments/230/230949-33029ae84c4ebcc5c45062f33987e355.jpg)
![PXL_20240724_231621992.jpg PXL_20240724_231621992.jpg](https://diysolarforum.com/data/attachments/230/230950-b7996868dbc21768eca5c8c3b535c1b0.jpg)
I can get a similar unit, same brand and volt/amps for $ 99 and swap some connectors easy enough from Amazon.
My gut says go that way.
https://www.amazon.com/Universal-Re...454246526-B0BPQF5Q1T-&hvexpln=73&gad_source=1
The exact replacement with the same connectors is stupidly priced around 200 for no other reason than, they gotcha.
