I would like to receive suggestions for a replacement inverter for my Outback Radian 8048A. I want a hybrid inverter that can pass AC through to my load subpanel all of the time (grid tied mode). I have a 50 amp 240 volt AC input into the Radian from my main loads panel and a 240 volt 30 amp generator input too. These are selectable and there is automatic backup via battery and generator. The inverter and lithium battery combo should be UL 9540 and UL9540A, and closed loop RS485. Inverter capacity of 10-12k watts. PV capacity of 12k watts or greater. Built in MPPT charge controllers with at least 3 MPPT should be onboard. Time of use on batteries must be supported. Selling to grid must be disabled. Charging batteries from generator should be supported. WIFI or LAN support for remote control. Lastly I would prefer the newer high voltage input inverters and battery banks over the older 48 volt systems.
Any good thoughts and suggestions are very appreciated. Thank you.
