Hi All
My first post and I need some advice/help.
I have the following system:
Two Outback Radian GS8048 inverters (not the 8048A model)
Three Outback flexmate FM80 150VDC charge controllers
Two Outback GSLC load centers
Outback Mate3 system controller
Twelve Powersafe SBS 190f 12v lead/acid batteries (3 x 48v stacks)
8.25 KW installed solar panels.
The system is grid tied and batteries are only used during a power outage. The Radian system does use the batteries as a load stabilizer (correct term?) when in grid tied mode but the batteries spend 99% of time in float.
The batteries are at end of life and I need to replace them soon. I would like to use LiFePO4 based cells but don't know if my system can be adjusted for this battery type. I'm looking at the EG4 rack batteries or similar (SOK etc.) as possibilities. Want ~30KWH of storage.
I have read a few post here on similar Outback systems using these batteries but not with the Radian 8048.
So can I use LiFePO4 based rack batteries and if not what are my alternatives? I prefer not to use lead based batteries.
Thanks
Rich
Thanks
Rich
