I have a question I hope someone can help me with answering.
I have a 2019 Hymer Aktiv Loft edition with two 200ah Ecotrek lithium batteries. The battery bank is charged via a second 280 amp Nations alternator with a MC614 Balmer regulator. The system also has a proprietary Voltstart automatic start system that switches the engine on automatically when the battery voltage falls to a certain threshold to recharge them. There is no solar on the loft editions of this van as there’s a pop top on the roof for additional sleeping quarters. The lithium’s are wired in parallel with an AGM battery to avoid having to have a dc-dc charger. I attached a wiring diagram below.
The Ecotrek battery banks are notoriously unreliable and have documented failures all over the internet.
I recently purchased 16 280 ah cells from Amy in the hope of creating my own battery bank to replace the Ecotrek system. I have a few reasons to replace them as I (a) want something more reliable than the Ecotrek lithium battery banks, (b) need more power to hopefully power a 12v dc air conditioner overnight without hookups (system yet to be sourced and the current AC system is an undermount system that does not cool effectively), and (c) I want to be able to use the vehicle in freezing temperatures (current Ecotreks are mounted under the vehicle chasis and have heaters, but can‘t be used in freezing temperatures), which means I may have to move the batteries in the cabin or purchase better heaters if I choose to keep them under the vehicle.
By the diagram, will this endeavor be plug and play after I choose my battery configuration, BMS, custom enclosure? Will it work off the bat with my second alternator and Balmer, which is already programmed to charge lithium’s? Will it work with the voltstart system to automatically start the vehicle when the voltage is low enough to start charging from the alternator?
Thank you in advance!
