No Roof and I did find these certs for the inverter. I did not see anything about arc fault in NEC 2017 lots of stuff on rapid shutdown. I realy only need the permit for the panals on the roof. I hope I did not make a bad choice on the inverter. I also found this on the scc.That good news for the battery and bus bar. I don't remember when the Arc Fault requirement was first implemented. Are you ground mounting? That gets around the arc fault requirement.
Certificate-ESS-C10-11-Quattro-48-8000-110,-48-10000-140,-48-15000-200 (1).pdf488.9 KB · Views: 12
Certificate-ESS-C10-11-Quattro-48-8000-110,-48-10000-140,-48-15000-200.pdf488.9 KB · Views: 3
