solarenvy
First off, I was hoping to have my environment all setup and running by now. But here we are in May ‘24…and I’m pondering a complete redesign based on the constant stream of learnings (and frightening stories). This post is to solicit advice on a potential design pivot and whether I’m totally overthinking things.
Off-grid cabin (grid for AC backup)
2 x EG4 6000XP Inverters
10 x Solarever 455W panels
2 x EG4-LLv2 batts
Wiring design (and other details): https://diysolarforum.com/threads/dual-eg4-6000xp-wiring-please-review.78087/
I built a small — totally sealed, insulated and temp-controlled — “solar shed” adjacent to the cabin, about 30ft from the existing grid meter. The plan was to install every thing in there and have 2 dedicated 1.5” conduit runs to/from the shed and meter. The grid will only provide AC backup to the system. The PV panels are in the field about 75ft from the shed. I buried 4” conduit between the shed and PV array early on to make my life easier. This is the plan of record at the moment.
Then I got to thinking — will the shed be adequate? Is it too close to the cabin [in case of catastrophe]? Will I regret any of this?
In the meantime, I also have a recently completed workshop (garage) that is already offgrid on a small, portable setup. The garage is located about 60ft from the PV array, about 135ft from the cabin (in terms of pvc/wire runs). The workshop is isolated from the rest of the system and has a few dedicated panels on the roof.
What I was thinking:
1) Keep everything as-is and be happy with it, save some time and expense...but not anxiety.
2) Relocate all the gear from the solar shed to the workshop. This will require ~60ft of additional trenching / PVC / wiring to be extended to the workshop. I would have to run two sets of ~135ft wire to/from the workshop and cabin to interconnect to grid and main breaker. I can then consolidate power for workshop and cabin. An undertaking, but I would feel more comfortable overall (maybe).
So, the question really comes does to this -- what would you do in this situation?
2 x EG4-LLv2 batts
