Reusing 12 x SLA batteries in series/parallel - which way is best?
Podgyguy
Italy
I currently have 12 x SuperBatt DT120 SLA batteries in 12V parallel. I know it's not good practice, please don't troll me lol.
Now I'm upgrading to 24V, I'm wondering which is the best way to re-configure the 12 SLA batteries so I can re-use them more effectively.
I'm planning to connect the bank to the Victron Power In (which can take 4 separate lines in).
There's a good post here from coalfield that describes 6 x batteries in series/parallel with midpoint balancing (referencing the Victron wiring pdf).
But what about 12 batteries?
Is it best to just extend the example to 12 batteries and have a single line in to the Victron Power In?
Or is it better to have multiple banks to the Victron Power In (either 2 banks of 6 batteries with midpoint balancing, or 3 banks of 4 batteries without midpoint balancing) with the main leads to the Power In of equal length?
Or is there a better method?
(Batteries all same Ah/age/etc.)
If you are switching voltages anyway, why not just graduate up to 48V. Then you can wire your 12 batteries 4S3P, which is a much better configuration than 2S6P.
good point and I agree. but i want to re-use my existing 12/24v Renogy 40A controller (in fact getting another one to double up) and I have a 24V inverter lying around, and will add a few more panels.
so sticking with 24v for now as its cheaper, and gives me a better bang for the buck. 48v will come in a year or two hopefully as part of a much bigger upgrade ;)
i've seen a ton of YT vids by now. lots of vids on series vs parallel. but can't find decent vids on building a much larger lead-acid system.
what's best practice? serialise each set of 2 batteries into a 48V cell first, and then parallel them all? or parellel 2 banks of 6 batteries and then serialise?
or have multiple banks going into the Power In individually?
thx for commenting!
I would wire the individual strings for 48V, and the parallel three of them. If one individual string gets unbalanced, you can disconnect the others to charge up the misbehaver.
I would wire the individual strings for 48V...
Thanks for that. btw I made a typo on my question above, i meant 24v not 48v but i get where you're coming from.
I did the two main options as a diagram and it's becoming clearer :) well a little anyway maybe ... seems both options are equal on pros/cons ... option 1 is more simple whereas option 2 has more cabling but allows me to isolate each bank with a breaker before they "parallel" on the Victron Power-In bus bar - (assume main leads to Power In all same size). I don't see any other difference in the balancing as option 1 has midpoint balancing, so as I understand it, both as as good as each other?
I'm guessing you might be more in favour of option 2?
Appreciate the inputs! ?
Thanks for that, great to get the thumbs up! I'll go with option 2 then :)
Not sure how to refer to this layout - I can wire it no probs, but I have yet to fully get to grips with the nomenclature (xSxP, xPxS, etc). If I understand correctly, it's read from 'right to left' referring to 'inside to outside'.
So option 2 would be described as a 3P2P2S? whoa hang on, that doesn't look right :oops:
