CryptoNomad
- Feb 12, 2020
- 26
Hello solo female van dweller having major issues with my Etrek 2015. I bought it used in 2017 and it has been ongoing.
I am just not able to use the RV Electric unless it’s plugged in to an outlet. I was able to use the microwave and stove if I turned on the engine. But now I can’t even do that. So basically the only thing charging the batteries right now is the solar panels And I can’t even use the inverter for that
It’s been tested many times including most recently when alternator stop charging the house batteries. Mercedes followed the wires back to the box next to the batteries and the inverter and they said that’s where the power stops. Everything is fine with the alternator and the house batteries under the hood.
I did meter test on all those cables back there but they were all above 24 V
The main thing I’m seeing right now is the inverter is not receiving any power although I am able to use it when I’m plugged in.
The inverter has already been replaced one so I know that’s not the issue.
Sean from roadtrek said there should be a in line fuse where the equalizer is but I do not see it. I talk to the tech support of the manufacture of the equalizer in there is not a fuse.
The inverter has already been replaced one so I know that’s not the issue.Sean from road track said there should be a in line fuse where the equalizer is but I do not see it. Mercedes just tested the fuse
Sean from road track said there should be a in line cues were the equalizer is but I do not see it. Mercedes
At this point I really just need to have access to the batteries at least while the engines are. Does anybody know of any fuse that I might’ve missed?
I think I probably will switch out the batteries were with them if that’s the batteries that are causing the problems but right now I just need to get to that point so I have the ability to live on the road. There’s got to be a temporary fix thank you
attached is the image of the box with the plugs for the battery cables. Also is the equalizer, the battery layout, and I think a picture of the inverter showing zero for input.
FYI I’m in Redlands California right now at a park. I couldn’t even turn off the disconnect button the battery was so low. If anyone has experience and can help let me know. I am heading to Las Vegas to get some body work done on the RV so.
I would love to replace w/ lithium batteries and record it on video so if anybody could help with that in Las Vegas or around redlands I can pay, but also I would like to help and videotape so it is on YouTube.
