CryptoNomad
- Feb 12, 2020
- 26
hi thanks for the reply.Are you getting fault messages and alarms from the AIMS inverter charger? Have you verified individual battery voltages of all 8 house batteries?
Leaning to fuses, an inverter charger reset and possibly a malfunctioning battery charge control device. Do you hear the relay clunk when turning the house battery disconnect from on to off and or off to on?
Can you post the AIMS inverter charger model?
I found out from roadtrek technician that the fuse is actually part of the equalizer, if you have one. And I do. I already tested that and it does have full power. I’ve tested all the batteries and they all over 6 V
I have the sine 5000 W inverter. I am not sure where the AIMS charger is located. Is that a different inverter?
I have the disconnect and the other day it was hard to turn off because the battery was so low I think. It eventually turned off. I think it might’ve done some sort of reset because I have more battery power in that it’s lasting longer and stronger. But it’s only coming from solar still.
