Hello I’m trying to see if it’s possible to run a 12/24v dc mini fridge uses 90 watts no spike when the compressor turns on directly from solar panels. I’m thinking two 100 watt solar panels & some kind of buck transformer to make the power more stable?
Any help Innsite would be appreciated.
I know it would be better to use a battery & charge controller I just want to see if it’s possible for fun
Also since it can run on 12-24vdc do I need a step down converter to make the voltage more “stable” ?
Wills write up^
12v Solar without a Battery
If you have a small 12v appliance that you wish to power/charge when the sun is out, you can use a 24v\36v to 12v step down converter. This will modulate the power produced by your solar panel into a...
www.mobile-solarpower.com
