LivingTheDream
- Feb 15, 2021
- 135
Hello everyone,
First time posting, first time RVer, first time solar, so be gentle.
Inverter
Sincerely,
Brian
- So we live in Arizona (great sun), but we will be traveling a lot, mainly CO, WY, MT, MN, CA, and everything in between.
- I have a 44' Toy Hauler Fifth Wheel pulled behind an F350 dually.
- We have three A/C units, which I hope to not have to run, and if I do, then I'm doing something wrong.
- There is a generator that I'm perfectly fine running to help my systems short falls. Obviously, less is better.
- Residential fridge on 110v with an inverter that kicks off at 12v, which sucks and is causing food to spoil.
- Water Heater is electric and/or gas.
- Try to cook with the BBQ or Pellet Grill as much as possible.
- Both have laptops that only need charging once a day. Wife uses a large monitor on 110v.
Inverter
I realize that the inverter needed will only need to be big enough to handle those items that I would run at the same time, so a 3k should be sufficient. Let me know if I'm wrong.
Battery SizingI have 8 cells of the Lishen 272ah on order with Michael Caro. I'm looking at wiring these for a 24v system. The audit is saying 430ah and 10,300wh. Yikes! Maybe I should've ordered 16 cells. Can I mix and match Lithium Batteries, or should I just put in another order and pray China has their act together and it won't take another 3-4 months? Or am I off in my expectations?
Solar ArrayI have a big rig, but I cannot get 2472w of solar on my roof. Again, what am I missing? I thought I was going to be good at 800w of solar, wow was I off.
Alright, if I missed something, just ask. I look forward to hearing what you pros have to say!Sincerely,
Brian
