OK...been doing a lot of research but not finding anything specific to my questions.
Just bought a new 20'6" RV and want to upgrade the single lead acid battery to Lithium. Many of the places we camp don't have shore power and I could be out for up to a week at a time. I want to be able to run the A/C for a few hours as needed to cool the trailer down on really hot days. I know I won't be able to run indefinitely and that is OK...I just want to be able to extend the run time using combo of solar and small generator.
To that end, I bought:
2 x 300ah Epoch Essential batteries (specs say 200W max current with 400a/10 seconds)
1 x Victron Smart Shunt
1 x Renogy 400W solar Suitcase
1 x Honda 2200i generator
Still to purchase
Solar Charge Controller (not sure if I should get the Victron 100/30 or 100/50
Victron Multiplus (I think the MP II won't fit my space)
Solar Switch
Lynx Distributor (and fuses)
Class T Fuse (not sure what size I need)
Cables (not sure what size I need)
May add Cerbo GX and Touch 50 (haven't decided yet)
Attached is the potential design I came up with after research
The space everything is mounted in is pretty small (about 3 feet long x 18" wide and 18" tall. So all the components will be pretty close together for short cable runs. The fuse panel is about 3 feet about the battery compartment so it too is pretty close. The run from the shore power port to the compartment is about 8-10 feet. Trailer has 12V fridge, pump, stereo and a handful of USB ports around the trailer. It has AC plugs, A/C, Microwave (but will probably be removed), furnace and TV. I will likely add at least 1 intake fan and 1 exhaust fan that are thermally controlled to try and keep compartment temps down.
So my questions are:
Given the short runs for the battery to the lynx (no more than 1.5 feet), Lynx to chassis ground (about 2 feet), Lynx to Inverter/charger about 1.5 feet...Should I be looking at 2/0 cable or 4/0 cable?
How do I size the battery fuse?
How do I size the fuses used in the Lynx for the different loads?
How do I size the Solar Controller (100/30 vs 100/50)?
Any help is greatly appreciated.
Regards,
Java Jack
Still to purchase
Solar Switch
Regards,
Java Jack
