My system will contain the following:
4 × EG4-LifePower4 Lithium Battery | 48V 100AH
My solar panel mounts will be about 220 feet from the house. My understanding is that I will have to run 2 PV wires to each of the 2 (later 4) solar panel groups, 2 PV wires to each inverter.
Unless someone compelling talks me out of it, I plan to bury the PV wire deep enough (3 feet) to avoid needing conduit. Non-metallic conduit would run close to $1,000, as much or more than the already expensive PV wire.
Any guidance on the following questions would be greatly appreciated.
Is 19 strand PV wire (versus 7 strand) generally preferable for the above system?
Is it recommended that I use combiner boxes?
If so, do I need 1 combiner box for each group of panels for each inverter? (in my case, 2)
Thank you to anyone who knowledgeable and kind enough to provide me with some guidance.
SPNewbie
2 × EG4 6.5kW Off-Grid Inverters
4 × EG4 BrightMounts for Solar Panels (currently have 2 and will later expand to 4)
16 x Bi-facial solar panels left to purchase (likely 450w to 550w each)
2 x 500 foot spools of 8 AWG PV wire (uncertain whether 7 strand or 19 strand is preferred)My solar panel mounts will be about 220 feet from the house. My understanding is that I will have to run 2 PV wires to each of the 2 (later 4) solar panel groups, 2 PV wires to each inverter.
SPNewbie
