Sunday afternoon I was mowing the lawn for the 4th time and lost all power. When it quit the meter on the mower was showing 47.9 volts, 69.98AH capacity, and 46.0%. I checked the main fuse on the mower and it was still good. There were no loose wires or obvious signs of problems. I opened the BT app for the BMS and it showed 0% capacity, the voltage matched the 47.9 on the meter. The lowest cell was just under 2.9vdc and the highest just over 3.1vdc. Temperature on the 3 sensors average about 87°F.
I got the mower back up to the house and plugged in the AIMS charger but it wouldn't charge. The charger wouldn't even start, no LED indicators lit up on it. I pulled the battery pack and opened the box to see if there was any visible signs of problems. I can't see anything wrong, no loose wires, no loose nuts, nothing burned, no smell of burning. It looks just like it did when I put it in the mower.
Today when I went out to dig into it more, the meter was now 49.24VDC, 68.94AH, and 46%. It still doesn't charge though. I even connected the BMS leads to the charger to bypass anything on the mower that might be causing a problem. Still it doesn't charge.
The log data from the app doesn't show any red notes that would indicate a reason why it shut down. I did find in the parameter settings the cycle is set to 80AH which is probably why it shutoff at 69.98AH remaining, given my pack is 150AH total capacity.
So I can't find anything wrong, there's no indications in the BMS log of any errors.
The only thing I can see for why it quit was that it dropped below 70AH capacity. But why won't it charge now?
Any suggestions would be helpful.
View attachment 94013View attachment 94014
