Sailboat batteries: EVE/CALB or Fortune/Winston?
hmm, my 44ft boat is 41,000lbs fin and skeg, 7 ft 2 inch draft. we have done 37,000nm in here in the last 11 years with 3 Atlantic crossings. We dont get jolted by waves. We have never been knocked down.
Awesome for you. But, you realize the experience of your single boat doesn't reflect the combined experiences of thousands of others? Not planning for the possibility of a knockdown on an ocean going sailboat is irresponsible.
You assume so much. Who said I wasn't prepared for an ocean crossing. I have done several. In reserve, we have a complete lead domestic bank. We don't depend on the lithium at all. I will be doing another ocean crossing next year and one the year after. I also work with lithium batteries commercially doing consultancy work. I have no issues with aluminium cased batteries in a heavy bluewater boat. A small power boat puts cells through dramatically higher shock loads than they will ever see on my boat. Like a said, properly constructed compressed cells are way more secure than cells taped together in a drop in battery.
I would like to see the evidence of your thousands of others with destroyed cells from sailing boats. I will await your response with interest
I nev
I never said *you* were not prepared. This discussion is about what batteries are appropriate for an ocean bound sailboat. And for that, any ocean bound sailboat needs to be prepared for a knockdown. Then you stared talking about how you never had a knockdown, and it came across like they don't happen. They do. Boats must be prepared for them. I didn't mean thousands of boats have damaged cells. I meant thousands of boats experience knockdowns and hard jolts from rouge waves.
I also said that either Winstons or Aluminum case EVEs are fine if installed correctly, so they can't move. I don't think we disagree, as much as we misunderstood each others posts.
I spent many years racing sailboats and probably have 10,000 miles of ocean racing including a half dozen races to Mexico and we never experienced a knockdown but with probably a million sailboats on the ocean a few thousand knockdowns are likely. We had plenty of roundups in 40 knot winds but never a knockdown. Sailbags and gearbags moved around but everything else was fastened down.
Salt water? Unless he is planning on putting them in the bilge, they most likely will not see much salt water. Sailboat masts are made of aluminum and do okay with salty spray..
A great many LiFePO4 installs are in the bilge...
The OP will have to clarify where he is locating them and how much water they could be expeposed to. If that is the case and they are surrounded by bilge water then he may want to consider plastic shelled cells as mentioned earlier.
There are commercially available LiFePO4 batteries that are rated IP67 or better.
Of, of course, you could always install them in battery boxes.
Batteries will be inside some kind of home-built box (probably something like IP22), under the quarter berth. There are plywood bulkheads separating this area from the stern of the hull and the bilge where there might be seawater splashing around in extreme conditions. So I don't expect the batteries to get wet or salty other than through condensation and airborne moisture & salt.
Long range plans include crossing the South Pacific. We're not expecting huge waves, knockdowns, or round-ups, but want to be prepared for that possibility. Kinda like we aren't planning to be hit by lightning, but understand that it might happen.
I'm my opinion, that's a very poor choice for any battery. Our batteries are under the saloon seats. Central in the boat and well above a deep bilge. The battery box is waterproof up until water flows over the saloon cushions
Does anybody know whether EEL Battery is one of the reliable sources?
Thanks, everyone, for the input. It's helpful. The point about larger cells having more internal inertia is helpful. "Most of the time sailing is more gentle than speed boats, but once in a while you hit a big wave," sounds about right to me.
They are a horrible company. I bought one of their metal battery boxes for 280Ah cells on Amazon. After a month, (it was supposed to be at my door in ten days), they still had not shipped it. Eel then sent me a note saying it needed to go by ship and I should have it in three months. I cancelled the order and they never issued a refund. A few days later I noticed they were no longer on Amazon. in the end Amazon did the right thing and issued a refund. Eel is just another Chinese scammer with horrible ethics… I would not touch that company with my worst enemies 10’ pole…
I nev
no he seemed pretty full of himself to me as well.
I'm partial to the Fortune cells. They aren't the cheapest or lightest, but they have a design that permits constructing a solid battery in pretty much any configuration you choose using ss threaded rods and nuts.Just my two cents. YMMV
In my sailboat I used 100Ah batteries. One reason is they are half the weight and size of a 200 Ah battery. Easier to carry down the companion way. More options to orient them in the rack or under the seats. When I moved my batteries out of the engine room, away from the heat, and placed them in the salon under the sattee the boat sat level. Previously it listed to the galley side, which was heavy with the stove, refrig, freezer, hot water.
I also have fortune 100Ah cells in my sailboat, 1200 Ah worth. I am trying to find where to get the red 18-22awg connectors that will fit over the 10mm posts on the batteries. I can’t seem to find them or the 7/16 ring terminal size anywhere.
Does anyone know where I can get 20 of them?
john
john
I get all of my wire and connectors from pacer.
Digikey is fine for the terminals too, I guess. But pacer has a good selection of tinned wire and boat cable as well.
I have been buying battery cable at bestboat wire.com, and other assorted heavy duty terminal lugs etc. I am now in New Zealand and the site comes up as https://www.boatwireusa.com/ They just did not have anything in 18-22 awg for the fortune 100Ah 10mm metric posts. DigiKey had them and something else I needed, so it was a good idea.
john
