Bill Taylor
- Apr 30, 2020
- 75
That is what I was thinking Bill. What battery charger were you thinking about for $300?
I will dispense my advice and opinions at my own peril. I don't want to start a pissing match about which charger is the best. But since you asked me....
I like the Xantrex 458 2000w inverter/chargers. They can be found used for about 300 bucks. You get the 2000 watt continuous duty inverter, 30 amp transfer switch, and 100 amp charger in one box. Yes, they are modified sine wave. (I would be happy to have a "modified sine vs pure sine" discussion with anyone). And yes, they are dated technology. But, their giant Transformer allows for a massive surge and they are built to last. Every year I see at least 50 or 60 systems with those being used 24/7. Very seldom do they fail. And when they do, anyone with basic electronic skills can repair them. They have several charge profiles to choose from and temperature compensated charging. I haven't noticed a lot of people talking about temperature compensation. If your batteries ever get outside of the 60 - 80 degree range, temp sensor is a must. (Except lithiums.) I will not use a battery charger that does not have a temperature sensor on it. They will even work fairly well with lithium, better than the Magnum's. It would be really easy to hook the air conditioners up on the inverter output and put a lamp timer on a line cord for the AC input. Just have the lamp timer shut the input power off between 3 and 8. The battery is charged off-peak, you're running everything off the batteries for a zero draw on peak.
Progressive Dynamics makes a really great multi-stage charger for under $300 new.
I have seen a lot of pretty impressive looking Chinese chargers and inverters on the market. And I have tested a few of them out. I have not tried them all, but so far, I am not too impressed. Again, just my opinion
