Two CC Schneider 60/150....5.9K in pvWhat charges your battery?
That when I sell to the grid I don't draw amperage from my batteriesOk, and what specifically are you looking for the inverter to do?
DC coupling PV to batteries then using inverter to sell AC power to grid always puts 120 Hz ripple current on batteries. The peak-to-peak ripple current is twice the average inverter DC current, 120 Hz AC sinewave current centered on average DC current is swinging from near zero to twice the average current.That when I sell to the grid I don't draw amperage from my batteries
The short version is set the grid support voltage higher than battery voltage.That when I sell to the grid I don't draw amperage from my batteries
Thank ... I'll follow those recommendations and then I'll let you knowThe short version is set the grid support voltage higher than battery voltage.
Edit to add that the MPPT much have charge settings that are higher than grid support voltage.
The inverter will sell any energy it can get that is above the grid support voltage setting. If you enable grid support when the battery is above that setting, the inverter will dump that to the grid. Try enabling/adjusting grid support in the morning when battery voltage is lower.
Longer versions involve requests to see all your settings.
Thank You!The short version is set the grid support voltage higher than battery voltage.
I have more than 25 hours into this problem. Thank you so very much for giving me the "key."I have installed a Schneider XW Pro Inverter with their MPPT 100 600 charger and Lithium Smart batteries. I have the latest firmware. The unit works great from a performance point of view, seems quite efficient based upon heat it dissipates and is incredible at handling surges! I have a 6 HP 240 V compressor and it starts it without the slightest hesitation. However, I am also selling to the grid. I wanted to do their Enhanced Grid Support. Meaning… keep batteries charged, use the power from the PV to run the house and sell any extra to the grid. I scoured the documents and the WEB and could not get information for it to work properly… meaning: It would only sell to the grid at the rate of the “max sell amps”! The impact of which was to discharge the battery at a high rate until the batter SOC (or voltage.. depending on mode) would be reached and then it would stop using energy from the PV, the house would be fed from the grid, the battery would then be recharged to above the SOC limit and then the cycle would start all over again! Constant large current cycling of the battery about every 55 seconds.
I called technical support multiple times and all they gave me was the manual information and said it should work… but it did not.
In searching the WEB, I found multiple people encountered this problem but no one including Schneider had a solution! Well, I stumbled upon the solution… They say that the Grid Support voltage should be set to 64 Volts in order to enable the Enhanced mode. That does not work. I have verified this on my system and the exact system of a friend of mine (we bought same equip. at the same time).
The answer is to run it in the SOC mode but have the Grid Support voltage at the float voltage of the charge controller! Then it works beautifully!!! Just a note: the charger settings on the MPPT must be the same values as on the Inverter.
I wasted about 25 hours with this issue and Schneider was no help at all. I believe that at this point I understand the system better than their technical support people.
If any of you struggled with the same issue… I hope this will help you!
I and my installer have wasted a lot more than 25 hours over the last 3 months. I tried the 64 volt trick and of course it did not work. I tried setting grid support voltage to the floater voltage voltage and that did not work. I have a whole list of " tricks" from various manuals and blogs, some of which seem magical and others that seem reasonable but do not work. Nothing seems to work. I am beginning to think there's a fundamental flaw in the latest firmware. For my next trick, I plan on shutting everything down, disconnecting all power, and leaving it to cook overnight. Then I will reboot all the components one by one to factory defaults. Then I will go through and correct those parameters that aren't right.I have installed a Schneider XW Pro Inverter with their MPPT 100 600 charger and Lithium Smart batteries. I have the latest firmware. The unit works great from a performance point of view, seems quite efficient based upon heat it dissipates and is incredible at handling surges! I have a 6 HP 240 V compressor and it starts it without the slightest hesitation. However, I am also selling to the grid. I wanted to do their Enhanced Grid Support. Meaning… keep batteries charged, use the power from the PV to run the house and sell any extra to the grid. I scoured the documents and the WEB and could not get information for it to work properly… meaning: It would only sell to the grid at the rate of the “max sell amps”! The impact of which was to discharge the battery at a high rate until the batter SOC (or voltage.. depending on mode) would be reached and then it would stop using energy from the PV, the house would be fed from the grid, the battery would then be recharged to above the SOC limit and then the cycle would start all over again! Constant large current cycling of the battery about every 55 seconds.
Of course it would be nice to be able to save and reload parameter sets, but when I try to upload a previously downloaded configuration, it hangs my Chrome browser. I am not surprised. I am reduced to opening all the tabs and then printing that page. I can then go back and reset all the parameters, one by one, tedious, and not helping my current frame of mind.
My xw Pro and batteries are new. But now I am researching other products like Outback. LOL.
One sec, I want to make sure I'm not misunderstanding.I did the full shutdown and factory reset procedure. The system is now running but continues to draw power from the battery when the solar panels are producing more than enough. Enhanced grid support should not be doing that. My system is intended as a backup system and should only draw power from the battery if the grid and solar are not sufficient.
If load shave is 0 amps, and SOC is set to 100%, it will use PV generated power to support the loads only when the battery is full.. When the PV power goes away (dark, clouds, etc) then it stops supporting the loads and uses the grid to satisfy those. Enhanced grid support prioritizes the batteries.Load Shave Amps is the value used to determine when the inverter starts to supplement loads using battery power. So If it is set to 0 then NO current will be drawn from the grid and the inverter will try and satisfy all loads from the batteries. This is exactly the opposite of what Hamish is wanting to do.
I would agree with this.That makes sense when adding SoC into the mix. This is a variable I don't have available with the XW+. So if you needed to actually have Peak Load Shave kick in at say 4pm for TOU the SoC setting would have to be reduced to less than whatever the battery is presently at.
It sounds like the problem described in the post was due to Enhanced Mode not working correctly on his inverter.
Insight Home/Facility v1.18 is out. It is supposed to fix the enhanced grid support problem. v1.17 was also supposed to fix that problem. Neither of them fixed it as near as I can tell. Thank you Schneider solar.I have installed a Schneider XW Pro Inverter with their MPPT 100 600 charger and Lithium Smart batteries. I have the latest firmware. The unit works great from a performance point of view, seems quite efficient based upon heat it dissipates and is incredible at handling surges! I have a 6 HP 240 V compressor and it starts it without the slightest hesitation. However, I am also selling to the grid. I wanted to do their Enhanced Grid Support. Meaning… keep batteries charged, use the power from the PV to run the house and sell any extra to the grid. I scoured the documents and the WEB and could not get information for it to work properly… meaning: It would only sell to the grid at the rate of the “max sell amps”! The impact of which was to discharge the battery at a high rate until the batter SOC (or voltage.. depending on mode) would be reached and then it would stop using energy from the PV, the house would be fed from the grid, the battery would then be recharged to above the SOC limit and then the cycle would start all over again! Constant large current cycling of the battery about every 55 seconds.
When you guys say enhanced grid support doesn't work, What specifically are you thinking it does or should do, and what is it actually doing?Insight Home/Facility v1.18 is out. It is supposed to fix the enhanced grid support problem. v1.17 was also supposed to fix that problem. Neither of them fixed it as near as I can tell. Thank you Schneider solar.
Apologies, I'm still not clear on what the issue is, or what you are trying to get it to do that it's not doing.When on Grid Support, it will export battery energy even if more than enough solar power for the load. If I turn off GS, it will not export to grid. I suspect this is a feature. It has always seemed to me like there should be a grid support-conserve battery option. Maybe I missed that.
On-Grid
XW Pro 6848
MPPT 80-600 x 2
Discover 42-48-6650 Li-Ion x3
Generac 6730 20KVA
300-w panels.x24
But with Discover BMS, battery type=Discover 6650, the XW must be set to 2-stage charging, thus no float stage at night. At night, XW periodically draws power from batteries, then recharges. I could set Recharge % to 100, but BMS overrides and sets it to 98%.According to the release notes for the latest firmware, there are issues with the Enhanced GS. However, the give a "workaround".. which does not work!
I am still using closed loop SOC control, however, they still use voltages to do the actual control of how much power they take from the DC bus and how much they export after supporting the house loads. So what one would think is a completely SOC-based control is not so... it is a hybrid mode. Once the magic trick is known, mainly having the Grid Support voltage be the same as the Float voltage then it works magically. All their instructions say to have it not at Float but at a magic number "64". When I did that it just kept oscillating with the high discharge/charge cycles.
I expect it to NEVER sell battery energy to the grid.Apologies, I'm still not clear on what the issue is, or what you are trying to get it to do that it's not doing.
If you want it to export excess PV energy to the grid after the batteries are full, thats what enhanced grid support does.
The way it works is:
you set your grid support volts to 65.
You set your inverter to 2 stage charging (or disable it completely)
you set the Schnieder SCC (it must be schnieder, and connected via xanbus) to 3 stage. Set your bulk, absorg, and float voltages to whatever makes sense for your batteries.
When the sun is shining, the system will prioritize charging the batteries. Once your SCC switches to float mode AND the batteries "rest" down to float voltage, the XW Pro will begine exporting the energy being generated.
The last part is key. A lot of people think it's not working because they set float lower than bulk/absorb. So the SCC charges the batteries to (for example) 56v, but then the SCC switches to float at 54v. While the batteries are above 54v, the SCC doesn't want to "overcharge" the batteries, so it produces no power. When the batteries hit roughly float volage, the SCC will start producing energy from the available PV.
Depending on your battery chemistry, it can take a while to let batteries drop to that float voltage. So my recommendation would be to set bulk/absorb/float all to the same voltage. If thats not an option, enable the settings and watch it for a while. see if it starts exporting when the voltage drops after the SCC's have switched to float.
If that helps, cool. If not, please write a detailed description that includes 2 things. 1) What you expect the system to be doing. and 2) What it's actually doing. Please make sure to include config details/parameters.
On-Grid
XW Pro 6848
MPPT 80-600 x 2
Generac 6730 20KVA
300-w panels x24
