400bird
Solar Wizard
?In case there is an excessive interference from MPPT when I use my radio equipment (not happening very often though). An ability to shut down MPPT controller from my office where I have radio stuff is a plus for me.
Midnite has great tech support, but including real people on the phone. I'd recommend calling them.
Schneider has gone through a few iterations of the product, one was specifically named Gateway. All had the same basic functionality. The Insight Home and Facility give you the same access into the unit. The Facility has double the number of ports and better wifi.But their "insight home" is a gateway that allows to change setting, do EG4 battery integration and etc. At least with XW Pro? Or am I missing anything? I thought they only have "Insight home" and "Insight Facility" and both can do settings and etc.?
Just t the XW pro, insight home, and mini PDP.May I ask you what else do you have with Schneider name on it? PDP? I'm thinking about making my own PDP (din rail box really with DC and AC breakers) as I already have transfer switch separately and I'm also tight on space in my garage.
The mini PDP was pricy for what it is (need box, breakers, wiring) but it fits great, did everything I needed, including getting through inspection.
The 21v and 24v panels in series is pretty close to a 44v panel. I'd want to compare VMP.I corrected my previous post with some extra info. I got those used panels when I was still planning to stay with 6500x. And they were not that cheap either. Like $240 for two.
But, that would be a complicated area to set up.
